yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
This one is at 61mm !
Tomorrow both clutches coming off and full disassembly and inspection.
Also need to make sure his stub shaft bearing is seated properly to make sure the offset measurement is accurate before machining
RAMSOMAIR
What a mess!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
They will be pretty once I am doneWhat a mess!![]()
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I’m running a 45 degree helix with HH thunders at 67 grams. Thunder orange at 6/3 in secondary. 22/41 gears. Offset set with hurricane bar. 3mm machined of secondary stub. 10k miles no blown belts. Floats the skis up past 80 mph easy on hard pack. Temped with gun and hands tons of times. Never seen over 160 on primary or belt. I know most think this is to much helix. But I’m going on a tree trunk saying more helix angle really wakes these winders up. 270 tune. Corner to corner is hard steering as the skis just float about 2-3 inches.
57.4 mm offset!!!!’
57.4 mm offset!!!!’
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
lol so mr knapp was right!, its closer to a 48 then a 38!!View attachment 159248
STM 38!!! Not
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
STM 38!!! Not
Ah, didn't I say 45 or 46 as I recall?
Wait, we're in the wrong thread.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I’m eating Knapp crow sandwich mike. You were right again.Ah, didn't I say 45 or 46 as I recall?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I knew you were waiting!!! Didn’t take long !
justinator
- Mar 25, 2007
- Maine
Curious why there angles are so far off, I could see if it was between 37-40 I guess that would be "acceptable" but thats way out there. Wonder if all there angles are 7* off or if this changes depending on what angle you get?
KnappAttack
- Feb 19, 2004
- Welch MN
From what I see they are all off like that. I had a buddy burn right thru the secondary trying to run a stm helix before. I always thought they were just cut wrong, but that's their MO.
I ran a Dalton 45/33 the last 2+ seasons and loved it. I really think the Heavy Hitters give you the backshift you are giving up with the steeper helix.I’m running a 45 degree helix with HH thunders at 67 grams. Thunder orange at 6/3 in secondary. 22/41 gears. Offset set with hurricane bar. 3mm machined of secondary stub. 10k miles no blown belts. Floats the skis up past 80 mph easy on hard pack. Temped with gun and hands tons of times. Never seen over 160 on primary or belt. I know most think this is to much helix. But I’m going on a tree trunk saying more helix angle really wakes these winders up. 270 tune. Corner to corner is hard steering as the skis just float about 2-3 inches.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
No issues with backshift at all. I know it goes against clutching 101 but mine back shifts great. Probably the way I have them loaded also. Stacked in the heels. Middle empty and the tip stacked also. That 45 start I bet you like!!!I ran a Dalton 45/33 the last 2+ seasons and loved it. I really think the Heavy Hitters give you the backshift you are giving up with the steeper helix.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Who's 45 are you using?No issues with backshift at all. I know it goes against clutching 101 but mine back shifts great. Probably the way I have them loaded also. Stacked in the heels. Middle empty and the tip stacked also. That 45 start I bet you like!!!
- 9K
- 12K
