jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Not a 45 it’s a STM 38. It measures at 45.Who's 45 are you using?
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Gotcha...I wonder how the Yami helix's compare to the Cat helix's because I run a straight 45 in my STM secondaryNot a 45 it’s a STM 38. It measures at 45.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Only one way to find out! Measure them. I actually do have a couple old cat helixes here. Maybe I will check them.Gotcha...I wonder how the Yami helix's compare to the Cat helix's because I run a straight 45 in my STM secondary
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Started a helix angle thread. Sorry thunder products. This is about clutch offset. Hi jack OUT.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I would like to here what guys have for offset that USED the hurricane alignment tool. I’m at 57.4mm.
Secondary locked down. No float
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
Secondary right against bearing 57.8. Still floating a bit.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
With the hurricane tool and the TAPP primary just under 60....
any less and the inside sheaves get dark.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
As the miles pile on these "Belt Blowers".....no blown belts yet
Nos bring that bar to the group ride. I should check mine. No issues but would think performance also would be improved if perfect. Thanks
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
I am going to be putting another few hundred miles on this weekend as well. I am swapping belts right away at the beginning of the weekend though. We will see if I can get the red-line to not slip/wear so badly. Will report on what she looks like after a hard weekend of corner to corner blasts.
- Apr 14, 2003
- Hessel, Michigan
Hey bud, due to some changes....I will not be attending the ride this weekend. Sorry bud
Have a great time!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Sounds great man! Let us know
Hopefully we can get all these belt blowers under control.
Oh man that sucks! Maybe I will ride to you Sunday. Call me tonightHey bud, due to some changes....I will not be attending the ride this weekend. Sorry bud
Have a great time!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Will do
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Got this sidewinder all set up!! This guy has been blowing belts original offset 61mm
Removed primary and checked that stub shaft bearing was properly seated . Bearing needed to be reseated and new offset measurement came in at 60mm. Had 2.3mm machined and now he is what I feel is "on the $$"
Offset is now 57.7mm!!
New thunder products 14.8 rollers should be here tomorrow and sled will go back to customer to ride the weekend!!
I will update on Monday if he blows belts or not...
I am pretty confident he will have no issues since I been pretty successful on helping guys with belt issues in the last 2 seasons following these steps!
1- remove both primary and secondary to disassemble, clean and inspect.
2- check stub staft and reaseat if needed
3- replace any worn or questionable parts in clutches
4- install both clutches and take a offset measurement (front outer machined edge of secondary to back outer machined edge of primary )
5 - have secondary hub machined to spec (57.5 to 59)
Remove spring and reassemble secondary and make sure the amount you machine does not affect full shift out (around 3 mm max)
6- install clutches and double check offset
- 9K
- 12K
