fourbarrel
Building a collection one sled at a time
Has anyone got a step by step on the lower steering pivot bushings install? I see a few pictures including the rivet removal of the reinforcement plate etc, but this would be a great thread to have to help those of us getting set to tackle this job.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
It was a bit nerve racking drilling that plate out but it made sense once I got into it
stgdz
- Mar 27, 2021
- Buffalo MN
Get a step bit
Turboflash
- Mar 18, 2019
- Southern MN
I just used a standard 3/16" bit. Then there's removing old plastic bushing. Just use the right length bolt with heavy washer as a way to install new bushings. I don't know if Mainway sends an install tool.
stgdz
- Mar 27, 2021
- Buffalo MN
I used a bolt and washer my first install and then a dead blow with a light tap and then a full tap on the next few installs.
REDLINE 1
I think I bought the puller he sells (basically just a threaded rod or bolt a washers) to install . Instructions were pretty good. Bought a cheap pneumatic riveter from harbor freight which was worth its weight in gold for the job. Also installed his greasable bushings in the a-arms
stgdz
- Mar 27, 2021
- Buffalo MN
I put the hauck rivets in the car sells instead of the ones that came with the kit.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Here you go.
Bell Crank Bushings and Install Tool
Are you shipping this bell crank bushing kit to Sweden? Are you on ebay?
ty4stroke.com
- 115K
- 9K
- 47K
