sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
lucky_7 said:T T T said:Blacked the spindles today, much better IMO.
Looks really good! Would look sick with a set of white skis!
Or maybe the blue and white muti-colored slydog ones from Ulmer???? That would be sick!
lucky_7
I am not a fan of the multi colored ones, but it would still look nice.
NLVMAX
- Jan 18, 2008
TEMP GAUGE INSTALL
AUTOMETER C2 ELECTRIC WATER TEMPERATURE TEMP GAUGE 7155
First I took out as much antifreeze out of the tank as possible. You will still waste some so use lots of rags.
I caught a lot in a small cover. Mark off a 1" wide area where
you plan to install the hose splice adapter. I used a marker.
Go ahead and cut slowly. Used a olfa knife for this.
Oh, I got the hose splice from http://www.ulmerracing.com/
Here is a pic of it as ordered.
It also comes with clamps.
Next, install hose splice adaptor. Tighten the clamps.
Next, I installed the temperature sender that came with the gauge.
Make sure you use tephlon tape on threads. Don't want leaks.
Next, I installed my 2 1/16" gauge holder.
This also came from Ulmer Racing.
Just what I was looking for and comes with different mounts. So you
can use what works best for you.
They are quite adjustable.
Time to run the wires.Put gauge in holder and tighten. Wires connects to back of gauge.
Connect wires into sender on the hose splice.
Now, ground wire from gauge goes bolted on the frame.
And I am splicing the red and white together from gauge
and going to the Blue/White wire in fuse box.
Pics of Autometer temp gauge installed.
Thanks for answering my questions Yamahammer485.
Goddo
- Nov 4, 2006
- 19 miles from Lewis Hills...Oh Ya.
NLVMAX,
you are doing a fantastic job with the installs. Very clean and good looking work.
Also a killer job on the posts. Very helpful and will give people lots of ideas.
Awesome...
My A-arm protectors came in today. Hopefully can find a few minutes to do the install tonight.
Awesome...
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
X2
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
Nice job and ulmer gets a
great products
kilometers
have you tried the mothers aluminum polish on the tunnel. night and day difference on my mtx..
Goddo
- Nov 4, 2006
I got the a-arm protectors installed this evening (well, all but one rivet (thanks wife --great holder). They look really good, and because its white on white it looks stock.
I'll post pics after adding the last rivet.
NLVMAX
- Jan 18, 2008
Thanks guys. Good to hear.
Started install of my oil pressure gauge. Plan on getting power from the 12volt dc plug which has a green wire and a white/black wire. Does anyone know what one to tap into? Haven't tested yet.
Goddo, looking forward to seeing that pic. Bet it looks sweet.
NLVMAX
- Jan 18, 2008
MOUNTING GARMIN OREGON 300 GPS ON NYTRO
Spent an hour in the Garage today and put my mount on.
Picked up a Ram Mount to install on the riser block.
Drilled hole through block to bolt on the small base plate which has a 9mm hole and a 1" ball.
Used a 1/2" bolt and lock nut.
Here's a couple pics of the mount in this position.
and
Now with the 1"ball on top. Not sure what way I will use it?
and
skyboz
Very nice work!!!
stopdropanroll
- Oct 8, 2008
- Fall River WI
The ball on top would be the way I would go. Looks good, I just ordered a Garmin 60csx with Ram mount thanks for the pics.
yamaslob
With the GPS into the up position wouldnt it be in the way of the grab bar, when your boondocken??? Either way sled looks good, those tunning fork symbol idler wheels are trick.
- 23K
