Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I posted on that. The SRX sure seems to be pulling the Mach in the first camera view then they are side by side in the second shot. I also don't think either were on the throttle as they passed the 2nd camera.
SledFreak
- Feb 7, 2005
- Ontario. Canada
You can here they uses the launch control, in what looks like soft conditions. That video does not say much as it looks like different races.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
It looks like the Mack suspension completely collapsed and dragged the running boards
To Me....it looks like the final shot of video was of the sleds on the roll out...usually the winner lets off early and the trailer always holds WFO longer .
Regardless a win is a win.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I'm feeling this video is misleading. As stated the yami jumped out at least two sleds then cut in front of the Mach.
What's that saying...."believe half of what you see & none of what you read."
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
Here’s a better angle….
They looked close in the first video. Not so much in the second.Here’s a better angle….
But how can this be, the Winders are soooo HEAVY!!
RAMSOMAIR
Must be tuned haha
Racy2
- Mar 16, 2005
- Toronto, Ontario
- 2022 Sidewinder SRX LE
Looks like fairly deep snow. With the SRX only 1 inch track and the Mach with 1 1/4 make quite a difference. Get the SRX on hard packed if you want it to perform to it's potential.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yep, in this sport snow conditions can be a great equalizer, or a great advantage. And that is just part of what makes it so much fun!Looks like fairly deep snow. With the SRX only 1 inch track and the Mach with 1 1/4 make quite a difference. Get the SRX on hard packed if you want it to perform to it'd potential.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I suspect the longer that race goes the further the winder gets ahead. Don't see the Mach none reeling the winder in. The doo guy should have hit the brake at 500 feet from the hole shot , through his hands up and declared victory ....
Where the Doo get the illusion of being fast is the hole shot they get because they transfer so well.
I raced with a well set up 900 Turbo that was tuned to 205 this weekend with my stock T Cat…….he jumped me and had good midrange, when he hit 90 it was like he pulled the parachute and I sailed by him by 10 mph easily…… as stated small turbo low RPM motor that doesn’t have top end near the 998.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Your stock or tuned
Real mixed bag of comments on dootalk about the new mach or 900r. Some don't think it should go over 110mph(which is ridiculous), and some are furious that it won't.
Not that I really care, but I'm wondering if doo programmed the ecu to recognize high intake air temps, and reduce power accordingly.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Nope it's just a toiletReal mixed bag of comments on dootalk about the new mach or 900r. Some don't think it should go over 110mph(which is ridiculous), and some are furious that it won't.
- 146K
