![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Here’s the deal. If in lower position (Yamaha)to have low ride height you need srx springs. To have the exact same height within 1/4 in it needs to be in the upper hole with std springs.(Cat) maybe bogeys are a issue I do not know that. Front is same for both.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Great research Canondale every thing is starting to come together. I don't think the boggies will be an issue.
All I know is I really should never have looked at that SRX. OMG is that a sweet sled!Great research Canondale every thing is starting to come together. I don't think the boggies will be an issue.
Only thing I am not sure of is the rails and if they have the same geometry. I sure hope they didnt mess with that Yamaha/Cat. Its simple enough to try for guys. Two boltsGreat research Canondale every thing is starting to come together. I don't think the boggies will be an issue.
It was me. Perhaps Yamaha wants to slow people down to lessen warranty claims? Put it this way if my sled were as high in back as what I saw I would be removing bogeys or whatever it takes to get it lower. CrazyThis Tech Exchange was posted last year. Cannondale, I think you may have shared it on here.
Yamaha came out with this notifying what the proper rear suspension mounting position should be based on the Non-ARCS and ARCS front-end. Would love to hear from Jaret what Yamaha found in their testing and why different from Arctic Cat's mounting position.
TPAY243
- Apr 14, 2013
- Northern Wis
X2 on the SRX Cannondale
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I have found running my front suspension with the arms almost level, Very slight incline, it handles on rails and steers nice. It is slightly lower than most but the new spindles would allow the same angle with an extra inch of belly clearance, it would raise my COG by one inch but maybe it would ok? Not sure but with my arms almost straight it’s on rails. Worth trying M2C
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
So this all is making sense to me now that I reflect back on my last two seasons. I have a '19 that I then converted over to the new ARCS front-end along with the new rail, etc. because I wanted to have the latest and greatest and needed something to do during the summer months. Well, now that I think about it, I had to run my ice scratchers a lot last winter due to over heating. The winter before that with the '19 setup, I rarely had to use my ice scratchers and never overheated. I'm sure the over heating had a lot to do with how high it sits in the rear. I may have to play with moving back up to the upper hole to see how it handles with the front-end changes.
Mototown
Did you miss the part where cat has been broke over the last 4 years ? And you still think they had more money than Yamaha to spend on testing the 4 stroke chassis? Cat hasn't even kept up with the motors , they are still on 800cc when everyone has 850cc for multiple years . To each there own .... but there is a reason why they changed their setup ... and it won't be to slow riders downMOTOTOWN you have no idea what kind of testing Yamaha actually does. Yamaha did a lot of testing on the Winder before it was introduced and not so much anymore all these little tweaks are developed by Cat and Yamaha does very little testing and usually with old parts.
I remember they put a stop on the link that bottom of rear shock is mounted too. So that people wouldnt mistakenly flip that link if suspension was removed. Could that be reason? Maybe only Yamaha did that? Need to look at those skids closely. This just seems nuts.This Tech Exchange was posted last year. Cannondale, I think you may have shared it on here.
Maybe so on a Mountain sled but do you think having that #*$&@ end so high is a good thing?Did you miss the part where cat has been broke over the last 4 years ? And you still think they had more money than Yamaha to spend on testing the 4 stroke chassis? Cat hasn't even kept up with the motors , they are still on 800cc when everyone has 850cc for multiple years . To each there own .... but there is a reason why they changed their setup ... and it won't be to slow riders down![]()
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
On my 2020 I can’t get my a arms completely level unless I loosen the springs past to where they just are sitting on the shock with no tension.
I’m not doubting you just saying my findings with the higher rear end.
That could be the reason for you over heating more but I didn’t over heat once on my 2020 and I did some long distances riding through towns on minimal snow to get fuel, had some morning where the trail was hard and crisp and still didn’t over heat.So this all is making sense to me now that I reflect back on my last two seasons. I have a '19 that I then converted over to the new ARCS front-end along with the new rail, etc. because I wanted to have the latest and greatest and needed something to do during the summer months. Well, now that I think about it, I had to run my ice scratchers a lot last winter due to over heating. The winter before that with the '19 setup, I rarely had to use my ice scratchers and never overheated. I'm sure the over heating had a lot to do with how high it sits in the rear. I may have to play with moving back up to the upper hole to see how it handles with the front-end changes.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Good topic keep this $hit coming
TPAY243
- Apr 14, 2013
- Northern Wis
TPAY243
- Apr 14, 2013
- Northern Wis
Mototown I'm not going to sit and argue with guys on this forum anymore it makes no sense. You think what you want but this suspension change had nothing to do with Yamaha I'm sure they tried to tweak it after they got there hands on it and looked what happens. I also think that Artic Cat is not as bad off as you think, there is a lot of changes being made right now. I'm not sure how this little bit of a change in suspension technology cost a bunch of money seeing how they have had it on there race sleds for years now. Anyways all good.
