ThatOneGuy'sBrother
- Oct 12, 2014
- Monroe County Norwalk WI
- 2020 Sidewinder LTX GT 2015 Apex XTX
That could make a difference!
Yes indeed! Now why does mine have shorter straps on it? There should be an update and a pn change if its different!
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Maybe release the straps and see what happens? Won't hurt if it's not ridden like that!
hellflyer
- Dec 2, 2008
Those may be 2019 and previous straps accidently put in! Same reason I found a self tapping torx in my air filter
hellflyer
- Dec 2, 2008
Maybe an early build and put in what they had? Who knows how they think at the cat factory? Maybe not at all! Lol
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
2019 limiter strap P/N is 8JP-G7495-20-00, and they're $5.24/per on Babbitt's.
2020 limiter strap P/N is 8ND-G6432-00-00, and they're $13.87/per on Babbitt's.
I don't have any other specs on these. Looking forward to your findings! Would be nice if this is a cheap/easy fix. I'm going to measure my dad's when I get a chance to chime in with my findings too.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Are you both SURE you are measuring the SAME place ? Time to go check mine.Measured my limiter straps. Center to center is dead nuts at 9 inches not 10. The only other hole looks like it would be at 7 inches. Otherwise there is no holes to make it longer.
hellflyer
- Dec 2, 2008
Center to center! Upper tube and lower shaft
hellflyer
- Dec 2, 2008
I could take a strap off tomorrow! Only takes a couple minutes if it’s slightly compressed
ThatOneGuy'sBrother
- Oct 12, 2014
Center to center on top shaft and bottom shaft. I also can completely remove mine. This would definitely eliminate any error! But its simple to measure.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Here are two pics of my dad's sled. First one shows side view where skid mounts to frame. Second pic shows distance to transfer blocks at rest. He measured 9" center-to-center on the limiter straps. Again his issue is that you can manually lift the rear bumper to max height, let go, and it literally drops several inches with no resistance at all. 2020 LTX GT.
Fast
- Sep 25, 2018
Currious what happens when you put a 2" board under the length of the track the sizzor should perpendicular then?Here are two pics of my dad's sled. First one shows side view where skid mounts to frame. Second pic shows distance to transfer blocks at rest. He measured 9" center-to-center on the limiter straps. Again his issue is that you can manually lift the rear bumper to max height, let go, and it literally drops several inches with no resistance at all. 2020 LTX GT.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
It's sitting on a flat concrete floor.. what do you mean? Thanks.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Service manual for 2020 states to use a 4" piece of wood when setting coupler blocks and leave wood in place while tightening bolts.Currious what happens when you put a 2" board under the length of the track the sizzor should perpendicular then?
ThatOneGuy'sBrother
- Oct 12, 2014
Identical to mine before adjusting the ski pressure and torsion springs on soft! After i let the pressure off of the front ski shocks it made a large difference in the uncoupled travel. I also changed my torsion springs to hard. Will be taking my BOP 4 position adjuster off of the apex and putting it on the sidewinder. Warranty according to the dealer i bought it from does not cover suspension sag unless the torsion springs actually break.
Because the front ski shocks are holding the front end up and the limiter straps are tight, the rear suspension is carrying all of the weight. Colapsing it down to the coupled bump stops.
There must be a change in the geometry of some of the skids. As other people are not having the same issue as your dad and i.
I dont think its only the limiter straps that changed. Because mine still hits the coupler blocks in the upper 3/4 of its travel. Once it hits them it takes a very large amount of force to get it to move.
After making those adjustments it seems like it will ride good. Mine has never been on the snow yet. So i can not definitively say it will ride good or bad.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Thanks Swampcat. I don't know if coupler blocks are the issue here though. It seems hellflyer and ThatOneGuy were looking at limiter straps as being a potential issue. Earlier in the thread it was suggested to tweak the front suspension to transfer more weight onto the skis and less onto the rear suspension.
- 10K
