Speed sensor is black patch on chaincase. Check the plug going to it. Tis right by reverse actuator. Bet it just wasn't plugged in well.Just had my sidewinder out and code SD_42 started flashing, it also said I’m going 261mph ...looking it up it says speed sensor, any idea what’s causing this, just got it back from the dealer doing all the updates and it was running fine.... is this a simple unhook the battery reset fix or worse?
XIpyretta
I’ll give it a try, I was the first down some beautiful groomed trails and this happens, thanks for the help.
XIpyretta
Reverse isn’t working either, any pics so I can compare what’s plugged in and not?
XIpyretta
Here are the pics I took, checked the ones that were plugged in, seem ok, now here are wires and plugs with nothing on them, still flashing the code and the reverse doesn’t work, checked the fuse looks ok, not sure of the relay, don’t have a spare , thanks in advance for any help.
Pstn head
The picture with you holding that black strip (speed sensor) well that should be mounted to your chaincase cover and receives signal from the magnets at your bottom sprocket. There's more than likely a little residue or fading area marking where it goes. I believe with some good quality high temp silicone you can glue it back on. All your plugs and wires seem to be pluged in properly, just double check them.
XIpyretta
Oh I hope that fixes it, thanks for the reply. I’ll let you know.
Pstn head
Any updates ?Oh I hope that fixes it, thanks for the reply. I’ll let you know.
XIpyretta
Not yet my sled is at camp, I’m hoping to get there tomorrow, the dealer who just had the sled said the same thing, silicone the black strip on and see what happens. This is also why it may not go in reverse, the computer is reading that the sled is going 261mph on the speedo.
Pstn head
Ok
Let us know then when you figure it out.
Great job Pstn head! No doubt that's the issue.
XIpyretta
Siliconed the black strip back on, started the sled, picked the back up and ran it , mph back to zero and reverse back working. Thanks for the help, saved me a trip to dealer ( now almost 2hrs away) and having to miss all the great snow fall!
Pstn head
No problem Bro
- 46K
- 29K
