I just received this info from Yamaha on the gearing of the SideWinder Models.
Track Lengths: 129 – 137 = 9T Drivers x 2.86 Pitch & 21/41 Gearing
Track Lengths: 141 x 1.6 & 153 X 1.75= 8T Drivers x 3.00 Pitch & 21/41 Gearing
Track Lengths: 141 X 2.25 & 153 x 2.25= 8T Drivers x 3.00 Pitch & 24/50 Gearing
Track Lengths: 162 X 3.00 = 7T Drivers x 3.00 Pitch & 21/49 Gearing
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Are these number subject to change? Good info Tom !!!
These are not going to change for this model year. From what I was told the other info that was out there was a mistake on some models but correct on a others..
Awesome! That should help alot.
Did you ask what belt it uses?
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The Sidewinder models will use the 8JP belt - same belt as ViperDid you ask what belt it uses?
woodzynh
- Sep 11, 2012
- Nashua, NH
- 2015 Yamaha Viper XTX LE
What's the top speed with the 8T 21/41?
SRXracer
@Port-Parts did I just see something on here about the narrow ski stance? Can't find it back now!?!
http://www.ty4stroke.com/threads/btx-mtx-mountian-adsjustable-ski-stance-update.141702/
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
A yamaha demo rep also told me this when I asked at the dealer. Is there any concern this will be able to handle the extra hp of the sidewinder? Seems to me there's somewhat of a difference in hp/power between a viper and sidewinder. Would assume the SW would be harder on belts.The Sidewinder models will use the 8JP belt - same belt as Viper
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
Not a sidewinder but I ran the 8JP belt on my turbo viper all last season with zero issues - I see no reason to panic over the belt choice at this point as it has passed yamaha testing for this application.
BornYamaha
- Dec 1, 2007
At 1 to 1 shift out at 8750 rpm the 21/41 calculates out to about 102 mph
Sent from my SM-G920V using Tapatalk
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
That was the gearing (21/41) and driver size (8T) in my Viper XTX w/MPI Trail Turbo this past season and seeing 100-105 on varying snow conditions was common - possibly a little more on ice/pure hardpack but I ride mostly trail/offtrail and didn't search out those conditions to try.
Is that the 141 1.6 cobra or did it have more lug than that?That was the gearing (21/41) and driver size (8T) in my Viper XTX w/MPI Trail Turbo this past season and seeing 100-105 on varying snow conditions was common - possibly a little more on ice/pure hardpack but I ride mostly trail/offtrail and didn't search out those conditions to try.
