Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
Yes absolutely safe on the stock muffler.Watched a TD Youtube about the range of tunes for Stock Muffler and Ben says use 3 Bar map sensor and Turbosmart BOV with SM Max Spool 16. Are these a must? Is it safe to run without these add-ons?
Blow off valve makes more boost and extra power. 3 bar is to get exact right reading at ecu for best tuning.
Max spool 16sm is the only big power fully trail tested and endurance tested stock muffler tune.
We recognized the need for high performance stock muffler tunes last season and started Early and tested for months before releasing.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
We can do it direct at TD or contact Tom ferry at arctic adventures. He is a dealer for us.Does one have to send their ecu to get flashed or are there dealers in NY that will flash it?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Ben
I am adding Turbo Smart BOV and 3 Bar Map sensors and keeping the stock exhaust.
Is there any special info or instructions for installing these?
Jack
Jack
actionjack
- Apr 9, 2005
BEN,
My Max Spool file says CAI. I do not have a CAI do I need different tune?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Mine said the same. It just runs a little more rich without the CAI.BEN,
actionjack
- Apr 9, 2005
Thanks Matt.
actionjack
- Apr 9, 2005
I haven’t flashed my dash so I don’t know what shows up there - I think the HP number shows up.Is this on the dash flash that it says CAI?
As I understand it the Stock Muffler Max Spool 16 tune file name starts with CAI_ ... everywhere. Ben PMed me and said it’s ok
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
On my phone last year it was listed as the max 17 lean on the screen but the flash file said max 16 CAI. I'm sure it's all getting sorted out by now.I haven’t flashed my dash so I don’t know what shows up there - I think the HP number shows up.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I also have max 16 and 3 bar and td bov and msm,and CAI was told it was 16.9 psi and close to 275 hp. is that correct?Max 16 sm is similar in power to your setup.
It runs a little higher in boost.
It runs best with a td 3bar map and blow off valve upgrade... We carry everything in stock.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Mod stock muffler is 270hp
Stock is 260
Cold air intake doesn't have a big influence as stock muffler is the restriction gives a little more hp same tune for both.
Stock is 260
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks Ben,ya I had keith woods do the flash,and his mod stock muffler,i already had the CAI last few years,was told boost pressure was close to 17 lbs with your bov,at any rate I was hoping it was more than your PT with same set up.Mod stock muffler is 270hp
Stock is 260
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
It's a big gain vs powertrail.
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
Tried my max spool 16 sm, still with stock bov and map sensor, big difference from ecotrail tune. Adding 3 bar map sensor and Td bov this week, need to add more clutch weight as well.Very happy with tune.
actionjack
- Apr 9, 2005
What weight are you running nowTried my max spool 16 sm, still with stock bov and map sensor, big difference from ecotrail tune. Adding 3 bar map sensor and Td bov this week, need to add more clutch weight as well.Very happy with tune.
- 14K
