Bigblue1
It's a big gain vs powertrail.
Ben I ran PT with SQ all last year and love it. I used Amsoil octane boost for piece of mind out in the Quebec bush. I got the power bug but I like dependable power. What would be the next dependable step, adding your bov ..3 bar map sensor? I would keep SQ muffler and add CAI. Thoughts..looking at dependable bundle option too.
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
Tried 72 g, need to add a bit, goes to 9050 on tach,
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ben on 91 octane,how long can I hold it WO,w/out knock light,this is 10% etho,even our 93 has etho at 10% I cant always get 93 we have either 90 none etho,or 91 and 93 etho.With my set up are all of those blends safe for wo 2500 ft runs?It's a big gain vs powertrail.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
BOV will add power too...Tried my max spool 16 sm, still with stock bov and map sensor, big difference from ecotrail tune. Adding 3 bar map sensor and Td bov this week, need to add more clutch weight as well.Very happy with tune.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ben,what do suggest for Dalton clutch set up for max16 MSM with CAI and map3 with TS BOV. I only have Dalton DTYA-1 ramps,but also have Dalton BLK/BLUE primary spring,and Dalton 41/35 helix and Dalton org/blk secondary spring,plus I could run stock 35 and Dalton org/blk spring,where do you like the degree settings with his secondary spring. And do I shoot for 8800-9000?BOV will add power too...
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I'm starting the season with almost this same combo, except a straight 35 Dalton and Dalton BLK/GRN primary spring. Interested to see what Ben says here - I was planning to try the DTAY-1's empty to start.Ben,what do suggest for Dalton clutch set up for max16 MSM with CAI and map3 with TS BOV. I only have Dalton DTYA-1 ramps,but also have Dalton BLK/BLUE primary spring,and Dalton 41/35 helix and Dalton org/blk secondary spring,plus I could run stock 35 and Dalton org/blk spring,where do you like the degree settings with his secondary spring. And do I shoot for 8800-9000?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Those weights are 74.9 grams heavy a bit especially with steeper helix. You will need a stiff primary to offset and I prefer the 35 helix.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
So stay with stock 35 and Dalton org/blk wrapped to 60 or 70 and Dalton primary blue/blk 54/133 be ok?Those weights are 74.9 grams heavy a bit especially with steeper helix. You will need a stiff primary to offset and I prefer the 35 helix.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Is that the old or new (updated) Dalton Black/Orange?So stay with stock 35 and Dalton org/blk wrapped to 60 or 70 and Dalton primary blue/blk 54/133 be ok?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Old one,do you think it needs to be replaced?Is that the old or new (updated) Dalton Black/Orange?
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Dale felt it was safer to do so - but also said the failure rate was pretty low. I didn't have an issue with the old one after 1000 miles, but swapped it out just to be safe. The main reason I asked is the wrap is different between the 2. The old one was 60°-70° depending on what you wanted and the new one is 80°. I haven't ridden with the new one yet, nor this entire combo but am pretty stoked to see how it feels compared to MS17/3" SanDale - LET IT SNOW!Old one,do you think it needs to be replaced?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
There was a batch of them that were bad. No way to tell for sure. Some of them broke. No difference in the new ones except they are painted instead of powder coated. Mine had a whole season on it with no issues so I just kept it. If you are worried call Dalton. Pretty sure he was letting you take before and after pics of destroying the one you have then just shipping you another one.Old one,do you think it needs to be replaced?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I stand corrected. Didn't know the wrap was different.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Tangs are in different locations and the required wrap is thus different. I believe the compressed rates are the same.There was a batch of them that were bad. No way to tell for sure. Some of them broke. No difference in the new ones except they are painted instead of powder coated. Mine had a whole season on it with no issues so I just kept it. If you are worried call Dalton. Pretty sure he was letting you take before and after pics of destroying the one you have then just shipping you another one.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
No worries at all - here's the link to the thread and Dale's instructions.I stand corrected. Didn't know the wrap was different.
- 14K
