scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
The paper says the new version has a slightly different tang location compared to V1 so it has to be set at 6-2 on V2 to get the same torsion amount as the V1 spring set at 6-1. Has anyone tried the version 2 spring at 6-3 ?The new version #2 B/O has more pressure on my drill press scale by quite a bit over V1. Tightening the secondary spring helps with top end slippage, raises RPM typically, and will backshift better.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
What are the characteristics if you go to far and put to much twist on the secondary spring
Thanks In advance
Reduced performance, hot belt and clutches. Same as too loose.
Too tight and it’s over pinching in the secondary, too loose and it’s slipping.
KnappAttack
- Feb 19, 2004
- Welch MN
I run 90 which is 6-3 on V2.
scottt
- Jan 30, 2018
- maine
You think that would be too much on my combo or ok to do?I run 90 which is 6-3 on V2.
KnappAttack
- Feb 19, 2004
- Welch MN
What is your combo? Power level? Helix, stock 8JP belt or 825 etc.
scottt
- Jan 30, 2018
- maine
All stock except for TD power trail 250 hp SM flash,,b/o secondary spring, rollers and dalton primary weights. 8jp belt. I'm hoping the shop actually set the secondary spring at 6- 2 like the paper said and not 6-1.
scottt
- Jan 30, 2018
- maine
TTTAll stock except for TD power trail 250 hp SM flash,,b/o secondary spring, rollers and dalton primary weights. 8jp belt. I'm hoping the shop actually set the secondary spring at 6- 2 like the paper said and not 6-1.
Fast
- Sep 25, 2018
How hot is your secondary running that at 90, i tried that for 10 miles and thought the clutch was going to catch on fireThats just too light IMO on the B/O. I run 90 on the B/O with Hi-Torque rollers. On the big tunes 80 is not enough and will slip pretty bad.
People don't quite understand that the stock springs are near coil bind at the end and actually apply a lot of pressure at the top end. They are wimpy down low however. You need to wrap up the B/O tighter to provide the top end hold needed.
KnappAttack
- Feb 19, 2004
- Welch MN
Not hot at all, actually cool. What rollers are you running and how many miles on the rollers? Also what helix? What speeds are you running at?
scottt
- Jan 30, 2018
- maine
I also noticed there are washers in between the helix and the clutch. I don't know if they were there when I bought it or after the shop installed the b/o spring and rollers.
KnappAttack
- Feb 19, 2004
- Welch MN
You don't need the washers under the helix if the primary isn't cut for OD. Some people did the washers because they thought, or were "told incorrectly" that the stock spring coil binds, which it comes close but does not actually coil bind at factory settings.
scottt
- Jan 30, 2018
- maine
I dont believe the primary has been cut.Can the washers hurt top end mph? After I blew the belt (8jp) that was on the sled when I bought it I replaced it with another 8jp and now sometimes squeals when at operating temperature and idling.You don't need the washers under the helix if the primary isn't cut for OD. Some people did the washers because they thought, or were "told incorrectly" that the stock spring coil binds, which it comes close but does not actually coil bind at factory settings.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I mentioned in another post on this topic but you need to adjust your beft deflection if your getting squealing at idle, your belt is a bit too tight. Remove a thin shim from behind the secondary mounting bolt and this should loosen your belt slightly and squeal will go away. It will have no effect on anything else.
Fast
- Sep 25, 2018
14.5 rollers 35/39 reverse helix pink secondary spring at 6/3 runs 110gps in around 1000 feet with 1.5" track, with the black orange at 80 clutches were cool but rpm kept dropping on the top end could only get 105, maybe a straight 35 helix would workNot hot at all, actually cool. What rollers are you running and how many miles on the rollers? Also what helix? What speeds are you running at?
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
I'm running 33/35 with the B/O Seemed mine ran hotter at 6-3 than at 6-2 also during back to back tests. Stock tune with new rollers in both clutches.
RPMs are down a bit with the XS belt (8600), but I haven't tried any weight changes yet.
- 108K
- 42K
- 45K
