SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
Just a random idea I had this morning. Has anybody looked at making a flip-able coupling block for the track? This way you can run with a coupled track on trail all day. When a washout/stream (or leaving the trail) etc comes up it could be flipped to uncoupled to hop the front end up and over. Finally it would let you switch back to coupled when returning to trail. Thoughts?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
There is a device available that couples an uncoupled suspension , but not sure about about uncoupling a coupled one .Just a random idea I had this morning. Has anybody looked at making a flip-able coupling block for the track? This way you can run with a coupled track on trail all day. When a washout/stream (or leaving the trail) etc comes up it could be flipped to uncoupled to hop the front end up and over. Finally it would let you switch back to coupled when returning to trail. Thoughts?
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
2013 apex xtx with woodys power up kit clutch work and mbrp pipe
Take the transfer block out of a 137” and presto. Uncoupled. Ran my ‘20 ltx most of the winter with the block out. Much funner on trail and much quicker off the line
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
I was going to say, once you get used to uncoupled, you may not want it back.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I was wondering if there was a way to make it tool-less and quick so it can be done on the side of the trail. That way it is possible to have the best of both worlds. On trail I normally run the twisties where I have found I ended up adjusting coupling almost as high as it would go on my old '06s. On the sidewinder I am trying to figure out a way to have my cake and eat it too.
4strokes
- Mar 13, 2018
- charlemont ma
need to move the shaft back and put larger blocks on it
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I was thinking of trying to move the shaft back then put the same size block on it with a flippable extension. That way when normal coupling is desired the extension is flipped forwards, when lessened/no coupling is desired the extension is flipped out of the way allowing more travel.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I do not believe the blocks have anything remotely to do with coupling , only travel .Take the transfer block out of a 137” and presto. Uncoupled. Ran my ‘20 ltx most of the winter with the block out. Much funner on trail and much quicker off the line
I found on my 17 LTX-LE 137 , that taking the blocks out did next to nothing , as sag takes up most of that travel.
I took off the blocks and moved the cross bar back about an inch , and along with the 240 tune and Yamaha replacement helix found some of the fun factor I miss from my Apex with the Star uncoupling kit .
I percieve the next step to finding incremental travel , is to go to the 240 SS tune , which initiates the turbo boost at a slightly lower rpm.
Ideally I want to get the travel /ski launch , to the point where I can install the blocks back in , so I have some easy adjustability.
4strokes
- Mar 13, 2018
- charlemont ma
I can tell you this from experience. couplers go through hell, so don't bother light duty
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
When the suspension comes back and hits on the block in the rear that is what a coupled suspension is. An XTX for instance in the sidewinder or viper has no block, uncoupled skid. I don’t want to put it back in. Way too much fun on the trial and way better launch off the line when drag racing. You can buy the speedo wrex block from Yamaha that’s adjustable but I love the pro cross chassis with out the coupling block. Just a blast to ride and loft the skis for 660 feet.I do not believe the blocks have anything remotely to do with coupling , only travel .
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Yup, when that rear arm hits the block it starts to compress the front shock,"coupling" the front and rear arms.When the suspension comes back and hits on the block in the rear that is what a coupled suspension is
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
Yes I understand that. Sled roll said e block has nothing to do with coupling. When that’s actually exactly what it doesYup, when that rear arm hits the block it starts to compress the front shock,"coupling" the front and rear arms.
fourload
Check this out. Pretty slick!Just a random idea I had this morning. Has anybody looked at making a flip-able coupling block for the track? This way you can run with a coupled track on trail all day. When a washout/stream (or leaving the trail) etc comes up it could be flipped to uncoupled to hop the front end up and over. Finally it would let you switch back to coupled when returning to trail. Thoughts?
http://www.skinzprotectivegear.com/snowmobileproductad/arc.html
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I am agreeing with you...……..Yes I understand that. Sled roll said e block has nothing to do with coupling. When that’s actually exactly what it does
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I may have used the wrong wording to explain my beliefs in this matterI am agreeing with you...……..
I am under the impression that coupling is the connection of the front shock to the back shock , so the back shock can react in unison with the front shock .
On a non coupled suspension the 2 shocks don't "communicate " .
On a non coupled suspension there is no pivot shaft and stopper as the 2 shocks don't "talk", so the shaft and blocks are not needed .
The pivot shaft with stoppers determine when the talking starts , not if.
Does anybody agree with me ?
- 48K
