Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
SJ, someone suggested to me to cut the quite lugs down? What are you thinking about that?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
in my opinion...its a waste of time..
bleedyamaha
- Sep 28, 2013
- Northern Iowa
So you are running 1.450s on your Sidewinder? Any clearance issues you can see? I need to order studs and leaning towards a mix of megabites and gold diggers in 1.450 down the middle but want to use all of the middle so may go back to 1.325s to be safe.Running 1.325's in a 1.250 track, you won't wear them out that's for sure. I like the mega bites my buddy runs triggers they look a little lighter time will tell on how they hold up. We both use 1.450's.
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Just make sure when studding over the quiet lugs you get them extra tight. I ran 3 seasons on my xf9000 and never had an issue with the studs coming loose or pulling out. I ran some real bad conditions last yr and studs did great.
Anybody have any feedback on SnowStuds Big Shot studs? Thinking 192 W84's.
indysnake1
- Jan 11, 2017
- ny
- sidewinder
run 1.630 triggers with tunnel protectors
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
W85. Very durable setup... Not an ice stud... But a solid trail stud if you go through some tough conditions.. Stay out of the middle unless you add protectors
indysnake1
- Jan 11, 2017
- ny
- sidewinder
I have a friend running the triggers in his 850 etec they h
got 800 miles on them and he trail rides mostly and hasent seen a problem with them yet.
- 24K
