- Nov 29, 2009
- sabattus, maine
Added another option to the poll per suggestion
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- 2015 LTX-DX
- 4000kms/2500miles
- All Stock except for a Hurricane Power Upgrade Kit
- No issues.
- 4000kms/2500miles
- No issues.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
2014 LTX SE
14 flash. 1,100 miles
15 reflash 1,300miles
Total 2,400 miles.
No hot start, cold start, nor kickback
Total 2,400 miles.
Yamadog
2014 XTX se MPI stage I since new 850 miles at 190 hp no starter issues but blew motor
Rebuilt motor and upgraded to 220 hp 1300 miles no starter issues
Upgraded to 252 hp 1600 miles no starter issues
2015 XTX SE starter kick back 4 or 5 times only rode it about 50 miles at the end of last season.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
2014 LTX se spring check. Had 1 reflash done in 2014 winter with 800 miles. No starter issues 2200 miles now. Mods as of now are clutching and can.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
14 xtx stock 100 miles. 1 hot start issue.
reflash and mpi turbo added. 280 miles.
380ish total miles.
OG starter.
380ish total miles.
OG starter.
14 Rtx
2500 mi with 14 flash 1 incident of low idle and codes. No start issues.
3000 mi with 15 flash. No start issues but rough idle without pcv tune. Never had a kickback with either flash.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
2015 LTX-LE Early build
800 miles
2015 Reflash prior to purchase
no kickbacks (I hold the key on to fully started), no hot start failures, sometimes sputters on start but I hold the key on 'til fully started. Never had to make more than one attempt to start.
800 miles
MADDOG24
2014 LTX SE with ECU reflash 3700 miles / original starter / no kick backs / Idled better from factory
allyammies
14 ltx se 3000 miles 2 no starts before flash, zero after but hold key till running.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Bought my 2014 xtx second hand. Had 1,000 miles on it. Now has 3000. No starter issues with mine. I do have the hot start issue, and have never had the ECU reflashed.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
2014 RTX
14 Flash- 2200 miles on original flash, had some (less than 10) hot starts and it threw codes a few times
15 Re-Flash- 800 miles, maybe had a few mild kick backs, but nothing that really stuck in my mind
Total 3080 miles.
If it breaks I will get it fixed. It's not worth worrying about since you can't really do anything about it until if and when it breaks.
Total 3080 miles.
Robinmaine
14 XTX
Original flash
1250 miles
Original flash
1250 miles
planner
2014 ltx se
reflash 2015
5700 miles
no problems on starter or anything else
reflash 2015
5700 miles
2014 XTX. 1,200 miles on stock flash. Many hot start issues but no kick backs.
Reflashed in late 2014 and hot starts went away. Both flashes had a surging idle. Still no kick backs and now at 2,680 miles.
Installed Hurricane 190 kit with PCV and now idle is smooth. No miles yet on kit.
- 33K
- 34K
