- Apr 14, 2003
- Hessel, Michigan
also needs another 2 .4 gm washers in the middle .
Thanks krm....I have this noted and will inform Lonn.
krm
- Apr 22, 2016
- ny
a
also add 1 thin at the tip ,spins 8900 then ,pulls like a freight train ,no more being a SLUG .Thanks krm....I have this noted and will inform Lonn.
Kevin
a
what belt?
krm
- Apr 22, 2016
- ny
8jp .gates 4313 nextwhat belt?
- Apr 14, 2003
- Hessel, Michigan
a
Thanks krm
This is what this is all about!
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Are you running the stock wind on the secondary?also needs another 2 .4 gm washers in the middle .
krm
- Apr 22, 2016
- ny
yes and i'm 245 lbs with 144 1.450 studs in a ltx le .Are you running the stock wind on the secondary?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Air filter still in place? I'm setting my kit up right now.yes and i'm 245 lbs with 144 1.450 studs in a ltx le .
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I'm suppriseed that the total weight is less with a shorter primary spring. I guess it's all about the profile on these arms. First time running thunder products in a sled.
krm
- Apr 22, 2016
- ny
yes ,if your lighter then me add 1 thin brass washer more on the tip .Air filter still in place? I'm setting my kit up right now.
slowride06er
Ice testing Rib Lake?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Monday I will be running somewhere on a lake. I know most guys work. But if anyone is interested in my area PM me
- Apr 14, 2003
- Hessel, Michigan
I agree with krm
I'm surprised that the total weight is less with a shorter primary spring. I guess it's all about the profile on these arms. First time running thunder products in a sled.
The aggressive profile these TP weights have work very well and the springs that Lonn sent me to try make the kit work....even tho they are shorter than the stock one.
Post your results here bud. That setup I gave you should be a winner... otherwise you might have to add some weight because you are LTX model. Hoping that helix comes today.
krm
- Apr 22, 2016
- ny
what helix .38/40 38/42??
- Apr 14, 2003
- Hessel, Michigan
I'm going to try a reverse angle 35/40. The 35 stock works well on the bottom, but for some I have tested...need a steeper angle to get more pull on top end
