hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Alarm concept is working out well. Planning to put a few trips on the set up to see how it holds up.
I do also have another possible solution that would 100% ensure tank never builds pressure, and 100% no loss of oil to atmosphere as well. Was in talks today with a reputable engine builder discussing the logic of what I want to do and he saw no issue. Now, to see if I can implement the concept. Stay tuned!
Fast
- Sep 25, 2018
Travis, any roll over valve updates on the new idea?Alarm concept is working out well. Planning to put a few trips on the set up to see how it holds up.
Any updates for us that needs a working ROV consept Travis?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Managed a little bit of riding this weekend on my new concept. So far so good.
Concept is to provide a secondary vent that serves as a bypass. It is still indirectly vented to atmosphere for pressure relief but any oil that escapes through the secondary bypass during a roll over just flows into the engine.
I will elaborate later with some pictures once I get caught up on orders.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Sorry it has taken so long for me to update. What I have been testing is a line that vents the oil tank via a hose from the oil tank fill plug and the valve cover fill plug. I have replacement plugs machined that allow for barbed hose fittings to be installed. The valve cover has a dedicated vent which vents to atmosphere, so in turn the oil tank remains vented in the event that the roll over valve freezes up. In the event of a roll over, any oil that escapes the tank via the by pass hose just drains back into the motor. Got close to 800 miles on the set up with no issues to date. If anyone sees any concerns feel free to bring them to my attention. I'm not an engine guru when it comes to the physics of pressures inside motor and tank but engine builders I talked with see no issue with my concept.
Awesome. I will take one and four more wheels!
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le
So is the sludge (moisture/milky white crap)still circulate through the rov into the intake or does it now go through the bypass hose and back into the engine?That is assuming rov is still plumbed factory way .
Turboflash
- Mar 18, 2019
- Southern MN
Is it just me, or why would you want that milky white oily goo going back into engine?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I have not been seeing any milky residue from condensation in the bypass and i don't think it will accumulate. By pass line should always remain condensation free since air passing through is going from warm oil tank to warm engine. There really is no warm to cold contrast for condensation to form.
Turboflash
- Mar 18, 2019
- Southern MN
My only comment is my sled has the complete bypass. When I start it up in the morning after sitting outside all night, I can see a faint amount of steam/water vapor (just like you'd see from your car) coming out of the bypass hose so I know there is water vapor.
rla1
- Jan 4, 2015
- saskatchewan
Thanks for the reply. With putting 800 miles on the bypass hose I was thinking that if there was any you would of seen it or signs if it in the hose.Now the next thing to do is find the best place to direct the milky oily crap other then the intake when still utilizing the rov.May be a baffled catch can.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Catch can idea is worth looking into!
rla1
- Jan 4, 2015
- saskatchewan
I seen in apost on here that a member installed one on his sled and it worked well.My only concern would be that if rolled over that the catch can beening vented would loose what it caught.
stohlem
- Jan 11, 2015
- 2017 Sidewinder LTX LE, 2014 Apex XTX
- Illinois
How about a rollover valve on the catch can! (Sarcasm) Couldn't resist.I seen in apost on here that a member installed one on his sled and it worked well.My only concern would be that if rolled over that the catch can beening vented would loose what it caught.
rla1
- Jan 4, 2015
- saskatchewan
Then would have 2 frozen rov's to deal with lol.
- 126K
