You guys ever open the oil fill cap on your car or truck if driven short distances in cold? The white slime is there too. Mine has 210000mi on it and hasnt hurt anything yet.
Fast
- Sep 25, 2018
Mine has a 50 micron filter to keep the oil out if rolled, i'll keep you posted when/if i roll her over and i vented it too the air filter so i can keep an eye on how its workingI seen in apost on here that a member installed one on his sled and it worked well.My only concern would be that if rolled over that the catch can beening vented would loose what it caught.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
Has anyone experienced freezing when riding?
The easiest thing to do is to loosen the oil fill cap while starting and warming up.
Worst is that you have to remove the side cover every time...
So perhaps the best solution would be a bypass valve (or a valve directly to atmosphere) on the hose from the oil tank that can be opened and closed from the driver's seat in a simple and flexible way. Without having to remove any side covers.
Open the new valve when cold starting. 10 min later you close and go..
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
A simple hose as many have done out the belly pan and your done. Lol
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Fast
- Sep 25, 2018
Travis from BOP has a sensor that screws in where the oil cap is an sounds the backup beeper if frozen,this would tell you to shut the sled off and do what you said, thinking about getting one since mine froze last winter, now i had the heated rov installed under warranty this year but thinking the hose from the tank could still freezeHas anyone experienced freezing when riding?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
It's usually the hose that does freeze not the actually ROV
Janne339
- Oct 31, 2015
- Sweden
- Sweden
So your hose out belly pan freeze too?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
No never had it freeze.So your hose out belly pan freeze too?
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
My dealer would not cover the heated valve,pissed me offTravis from BOP has a sensor that screws in where the oil cap is an sounds the backup beeper if frozen,this would tell you to shut the sled off and do what you said, thinking about getting one since mine froze last winter, now i had the heated rov installed under warranty this year but thinking the hose from the tank could still freeze
rock doc
- Mar 3, 2008
- Saint John, NB Canada
- 2018 Sidewinder XTX SE. Previous 2011 Nytro xtx, 2016 Apex GT, 1998 Polaris Indy 600 xlt
Saw this post while looking for options to bypassing the ROV. Did the alarm modification ever get worked out? Any other options?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
The alarm concept was ditched, as it really doesn't solve the issue. Post 65 shows my latest logic. Just have not gotten parts to production yet.
rock doc
- Mar 3, 2008
Thanks for the update.
NytroPturbo
- Feb 13, 2017
- Wisconsin
- Nytro Push Turbo
Travis, I get what you trying to do. On my Nytro XTX, I installed a push turbo where I use that valve cover breather as a return oil line from the turbo. For the oil tank, the Nytros have breather hose off the oil tank that leaks oil on belly pan after a rough ride so I rerouted it much higher with a longer hose which solved that oil leak issue (I could add an aftermarket ROV but choose not to). So what you are doing makes perfect sense and will work. When can I purchase your fix? As far as the AC/SW freezing ROV, its junk and your fix solved that issue. Kudos to you.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Is this not an issue with MY 20 and newer? What changed?
- 172K
- 8K
