Turboflash
- Mar 18, 2019
- Southern MN
Factory OEM design is there's a retaining ring on each end of shaft. Neither bearing is fixed to shaft. Shaft theoretically can float left/right some. Brake rotor floats on splines. My point is without the retaining ring on brake side, theoretically the shaft could float towards the chain case side, but only until the inner locating ring contacts the seal in caliper housing. Could it move far enough for the plastic/rubber drive shaft plug with the little magnets in it to contact the inside of the chain case? IDK what distance is? Doubtful but it is theoretically possible. But what if something hits the track shaft (branch, stick, piece of ice, etc) and forces it towards the chain case side? Then could the rubber plug in end of the shaft inside the chain case move far enough to contact inside of case?
Bottom line is leaving outside brake rotor clip off probably wouldn't be a big deal but in theory it could cause a problem.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The chaincase side of the shaft has a step on it so it will only go in till it hits the inner bearing race.
Turboflash
- Mar 18, 2019
- Southern MN
Then I stand corrected. Then, that snap ring really isn't needed.
Question, in real world riding, does that step do the limiting or does that clip outside the brake rotor do the limiting?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Chaincase side driveshaft is sandwiched, brake rotor side the inner clip never seems to be touched but the outer brake router clip takes some abuse. Poor design . I would think the outer brake router clip has to deal with the tunnel flexThen I stand corrected. Then, that snap ring really isn't needed.
Doo it’s pressed on. Need a puller to remove.How does Polaris & SkiDoo handle this bearing?
Locked or not bearing failure could cause brake lose. So can a number of things.
Hard to imagine a better solution than the wedge or pin.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Doo set up is very good
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Had conversation with senior tech at my dealer last week over what I am working on. He agreed with me that the seal really is not needed. He views it as more of a shield for debris as water gets behind it with ease. My new piece will all but shield the bearing, but I will be able to provide another seal as an option if one prefers to retain the seal.
Another question…
Let’s say I have a worn shaft and have means of installing a bearing that is true and on center. What loctite/liquid bond would one used to “fill in gap” between bearing and worn shaft? Someone suggested green loctite.
Another question…
It depends on how much is worn. Green Loctite will get Pulverized if too big a gap.Had conversation with senior tech at my dealer last week over what I am working on. He agreed with me that the seal really is not needed. He views it as more of a shield for debris as water gets behind it with ease. My new piece will all but shield the bearing, but I will be able to provide another seal as an option if one prefers to retain the seal.
Another question…
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
maybe develop some sort of "speedy sleeve" for worn shafts.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Locktite 648 retaining compound is made for press / close fit clearances. I think they make another version for looser fits
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I would buy a new shaft if there is any wear, then install your device. Not sure if I would want to try and "correct" a worn shaft.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Hard to believe that five years into the Sidewinder life we are still looking to fix a major design flaw that Yamaha won’t fix…..
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Tried bearing mount Green.. No go as the gap was to large. Turned it into powder after some miles. This is a 2021 8000 cat that the shaft was worn @ 180 miles from brand new from factory. I ran the sled for one trip without a wedge and its been garbage since. I looked up a new shaft a few months ago and it was "no longer available" NOT back ordered. ???
EDIT.. I do have a wedge on this sled @ 55lbs torque
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I think most that had green loctite fail were relying on it to hold the bearing. There will be no rotational torque on the loctite in my application. The force it is exposed to would really just be compressive force.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
How much wear does your shaft have? I will be looking for some people to try out my new concept on a worn shaft.
