Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
You have to understand, even if the tunnel or housing is "off" it will absolutly not wobble. It can ONLY wobble when the bearing is crooked on the shaft or the shaft is bent. Under no other circumstance can the tunnel or housing wobble.
The engineers did not design flex into the chassis or bearing. Nothing else can "break" if the bearing was held tight on the shaft. Ski-Doo does it right with a press fit on the bearing to shaft, and a snug fit in the housing that will not rotate, but it can take more effort to get it apart as the housing needs a bit of effort to get off the bearing.
The Wedge works well to hold things tight when tightened enough and normalized when tightened down so it doesn't cock the bearing on the shaft. The problem (wobble) comes when the bearing is not normalized straight on the shaft. It wont wobble with a good shaft and tightened in stages to nominalize on the shaft and not sit crooked.
Stainless set screws are not hard. You'd be better of with a regular steel set screw. The pin being used for this shaft anti-rotation mod reminds me of a piston ring locating pin, its just way too small. If you insist on using a pin or dowel like that, the old two-stokes used much larger anti-spin dowels in all the crankshaft bearings.
Knapp,
I have my '19 Indy xc apart doing some work on it. The bearing (drive bearing) on that sled seems like it is pressed on similiar to your BRP reference. So i assume when the time comes, the shaft will have to be removed from the sled and the bearing pressed off the shaft using a shop press or using 3 jaw puller. And then press on a new bearing.
Let me ask you this, if there is no flex in the tunnel and there is no need for the bearing to float, then why arent we all fixing them to the shaft via press fit? its just as easy to have a fabricator build the area with a weld and turn it down on a lathe to the right tolerance - (then no wedges, no pins etc).
If the SW had a press fit on the drive bearing, a puller would be needed (templated on the 3 mounting holes of the caliper housing) to drag the bearing and the caliper housing off the shaft (which i have fabricated). No doubt heat would be required. To reinstall - i can only assume the bearing would have to be pressed into the caliper housing first, then using a pipe (hitting only the inner race), drive the housing containing the bearing onto the shaft.
Thoughts?
MS
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have said this before, it is my belief that the bearing is not locked to the shaft because the bearing is housed in the brake caliper. In this instance, if you have a bearing failure, you could have brake failure. The bearing could spin in the caliper causing the caliper to fail. By not being locked to the shaft, in case of failure or seizure it will still spin on the shaft allowing the brakes to still operate.Let me ask you this, if there is no flex in the tunnel and there is no need for the bearing to float, then why arent we all fixing them to the shaft via press fit?
I could also be dead wrong....
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
YOu could but ideally the bearing gets pressed on the shaft first , the current design doesn’t allow this unless someone re invented the brake caliper housing.Knapp,
Thoughts?
MS
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Perfectly stated NYTurbo. They could have copied Doo and we wouldn’t even have been talking about this.
Or lock the bearing down with a nut on to a shoulder on the shaft.
The thing is this. The wedge works fine on a shaft that’s sized properly and torqued up well. The problem lies with people not torquing down enough, not properly normalizing the bearing straight on the shaft, or installing on a worn shaft without fitting properly. I torque them up real tight on new shafts from the start and all is well. Upwards of 60 ft lbs using anti seize on the wedge and blue loctite on the bolt after much spinning to normalize on the shaft. Never seen a problem or had the tunnel flexing after an install. I even put a dial indicator on the brake caliper to verify on install to make certain the bearing is not getting cocked on the shaft when installing. I doubt most people take the time or have the indicators do that, but I’m a perfectionist and have the tools.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Your raise a good point. If you were to drive the bearing in the caliper housing onto the shaft, god knows the force you place on the inner ring, let alone what can happen at the other end in the chain case.
MS
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
You will be impressed with what is coming out soonYour raise a good point. If you were to drive the bearing in the caliper housing onto the shaft, god knows the force you place on the inner ring, let alone what can happen at the other end in the chain case.
MS
STAIN
- Feb 29, 2004
- Vermont
- Vermont
From who?You will be impressed with what is coming out soon
- Feb 13, 2017
- Amston,CT
Thread #37 and #131 pictures of new concept coming soon.Barn of partsFrom who?
Turboflash
- Mar 18, 2019
- Southern MN
My bearing is pressed on. Shaft was spray welded, then ground on center to produce a .0003-.0005" press fit to bearing. I use BOP puller to remove it (with caliper housing) and a simple press tool to re-install. Press tool is just a 3/8" threaded rod with nuts and washers on both ends. It's made so it comes apart into 3 pieces to be able to insert inside track shaft without interfering with belly pan on either side (have to remove rubber plug with magnets in it on chain case side). I just remove caliper housing with bearing, service it, then just use press tool to re-install.Knapp,
Thoughts?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
How do u know when u have it pressed into the correct position on drive shaft ?
I like this method.
I like this method.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Did a complete install with the new concept today on my new 22 and ran it on the stand. Did not run into any issues. Few minor dimensional changes to make but concept works as intended. Maybe next week I will drop a photo of what I've come up with. Will likely release it this summer as I'm sure there are many with worn driveshafts eagerly anticipating a product that does not require them to replace the driveshaft.
Turboflash
- Mar 18, 2019
- Southern MN
Step on chain case side locates shaft against bearing on that side. I put both bottom gears on to make sure outer circlip goes on. Then press caliper housing on until it just contacts tunnel (not deform it or cause it go be pushed in). I put the 3 bolts in and start to tighten them. I just watch as 3 bolts tighten to make sure tunnel doesn't move. If need be, I can turn my outside nut to press in a bit more. It's very controllable. There is also no side load on bearing.How do u know when u have it pressed into the correct position on drive shaft ?
I like this method.
I've run my sled 3+ years now like this (6,500+ miles). No issues at all. Shaft can't spin in bearing. Bearing is replaceable (no need for machining a slot, etc). Everything looks like new when I serviced it this spring. Pic shows shaft after spray weld and grinding on center to produce a press fit to bearing.
swrtxlr
- Jun 29, 2016
- grantsburg
- 17 sidewinder rtx le
07 apex gt
00 srx olins
99 mountain max fully modded
gp 292
mod 292
You can measure the difference between the ID of the bearing and the OD of the worn shaft and cut a piece of shim stock half the difference and lock it in place. that what I did with mine 7500 miles ago when I added your wedge.Had conversation with senior tech at my dealer last week over what I am working on. He agreed with me that the seal really is not needed. He views it as more of a shield for debris as water gets behind it with ease. My new piece will all but shield the bearing, but I will be able to provide another seal as an option if one prefers to retain the seal.
Another question…
Let’s say I have a worn shaft and have means of installing a bearing that is true and on center. What loctite/liquid bond would one used to “fill in gap” between bearing and worn shaft? Someone suggested green loctite.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Here's a sneak peak of what's coming!
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Is that a bearing with an eccentric locking collar?
