saskattakman
it's mostly the oem spring that's causing the problem..watch your spring as the sled is reved up and down it deflects like crazy..I have never saw a spring chew a cover up in 500 miles and I've had 4 strokes with 15000 miles that looked better
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I believe that saskattakman has pretty much nailed the cause of the OEM primary spring breaking on some sleds.
I think that with the introduction of the new SW motor package last season that Yamaha had limited testing time with the new clutch set up and simply did their best with coming up with a reasonable clutch set up with the new primary and secondary clutches using their past experience with the 4-stroke motors. Let's all be thankful that the motor package was trouble free and I'm sure that's where most of their testing time was spent.
As last season progressed and some problems were identified in the clutches we have the aftermarket to thank in getting some solutions to the known problems along with some pretty smart TY members trying different springs, helix's and rollers.
It seems like the OEM primary spring was too long in length which resulted in the spring distorting during its travel, and most guys that installed shorter springs never had any breakage issues. It looks like most clutch kits that include a new primary spring also use a shorter spring.
At least those guys with new '18 SW's will have a pretty good idea where to start this season if they want to improve their clutching right out of the gate.
It's also interesting to note that Yamaha has not changed any of the primary or secondary tuning components in the new '18 SW models compared to the '17's: same weights/rollers/spring in the primary along with the same spring/helix in the secondary. They must be satisfied with the stock clutching set up as delivered last year.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Looks like you need TP's Glide Washers. Have you used them?
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
No I haven’t. Actually if you look at the ends of the spring can tell it’s twisting and wearing into the aluminum. Does this affect the spring compression numbers due to it being longer with the shims? Also noticed the spring isn’t square....probably out 0.250” against a square. Also 113.5mm in free length which is longer than spec 110.1mm
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I'd say at least one glide washer on the inner end will help. And many have benefitted from a shorter oem spring or dalton primary springs.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Agree. And as for the Glide Washers changing spring rate, technically they do. And TPI includes additional shims if you want to use them to adjust the spring rate and increase engagement rpm - but I didn't see any noticeable increase in engagement rpm when adding 2 glide washers, one at each end of the spring - just my results but I find the TPI Glide Washers work very well.I'd say at least one glide washer on the inner end will help. And many have benefitted from a shorter oem spring or dalton primary springs.
theewarrior
What helix are you running?I put cat rollers in early last year, all three contact my dalton helix nicely, never had a single belt issue in 2000 miles, changed belts mid season just because... 900 miles on TD power trail.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
41/35What helix are you running?
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
So what’s the options for replacement stock
gold-red-gold. 55kg/105kg rate 1.5kg/mm 110.1 mm length
Blue-Brown-blue 50kg/116kg rate 2kg/mm 98.4mm
Dalton - Black -bronze. 56kg/128kg shorter
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I ride yellow/white/yellow.
Dalton black/ bronze is probably very good to
theewarrior
Anybody hear if the 19s are coming with different coaching and possibly better belt? Anybody hear anything on this yet
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
I run a pink/ pink/ pink with two glide washers. Sled has 1400 miles on it and has the original belt. Sled is all stock and turns 8900 from bottom to top end.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anybody sell the TPI glide washers in Canada?
DMCTurbo
- Nov 12, 2005
Turbo dynamics and prevost performance to name a couple.Anybody sell the TPI glide washers in Canada?
