newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
My primary was machined on my viper and I picked up 4 mph with the 8dn.
Yep that works. Hurricane did mine
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
If your looking to bring the 8DN up a bit higher in the secondary like up higher over top of sheave edges, you will need to loosen your adjuster(turn it counterclockwise).. VS turning it clockwise will push sheaves apart or make belt ride LOWER in secondaryThanks. Thats why i did it a couple times. Kinda tricky holding everything in place and taking a picture. I havent ran it with the shim behind secondary yet. Might tighten up the osp adjuster a bit to bring the 8dn up a bit.
If you do this keep a eye on your rollers and if they pull off the helix > when you change deflection
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Thanks will watch the rollers. Already have one that isn't tight. Ya think a different helix and rollers will make them roll true?If your looking to bring the 8DN up a bit higher in the secondary like up higher over top of sheave edges, you will need to loosen your adjuster(turn it counterclockwise).. VS turning it clockwise will push sheaves apart or make belt ride LOWER in secondary
Pierre Castonguay
- Aug 25, 2016
- Saguenay, Quebec
- Viper, Apex, Sidewinder
As for roller spot and broken belt go with a 41/37 helix at 3/3, you might have to play with your primary weight but it will reduce belt tension and heat! The stock 35 helix on the secondary clutch is not the proper helix! With that set up never broke a belt, and trust me I ride my sled extremely hard! I will ride this set up until G force will have their 4D program for 12 lbs boost with proper primary weights!
newtron
- Jan 2, 2010
I have a dalton helix, cat rollers with the 8dn and all rollers are touching
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Not so sure about that. Example. Another member and myself both purchased STM straight 38 helix. He installed his and had two rollers not touching..Thanks will watch the rollers. Already have one that isn't tight. Ya think a different helix and rollers will make them roll true?
I installed mine and running a 8JP belt 1/16 or so under the sheave tops for deflection its almost as good as anyone could want. I have two that are extremely tight and one that is pretty tight(BUT ALL THREE touching).
these Secondary's are very inconsistent
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
So do we think the 8jp being shorter is breaking in half, due to it being too short?
and the 8dn therefore wont snap?
I can see running an 8dn then for day to day, then slapping in a 8jp for radar day for the extra 3mph.
Or is the snapping of belt gonna always happen when running 15psi?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Also the difference in compound could be contributing to speed factors and or longevity?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
the 8JP sure is a dirty belt compared to the 8DN. blowing belts and the carnage that comes with it sure isn't worth 2-3mph top end to me!
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
My sled is going to the dealer for a new primary clutch. Belt blowing and do some damage!
Fleecer
- Jun 13, 2014
- 2019 SRX
Went to my dealer last week and asked mechanic if yamaha has fix for belt issues. He told me yamaha is not aware of any problems because people blow belts, replace, and don't say anything. He encouraged me to call customer service and complain so they are aware of the issues. This will give them the knowledge they need to come out with a fix.
Do yourselves a favor....if you've blown a belt call yamaha customer service and report it: 1-800-962-7926
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I was at the dealer today to see about the belt issue. The manager called Yamaha, they told him the issue is when the belt is cold. On cold mornings you should warm the belt for the first 10 kms. Seems A bit of a shot in the dark too me.
The dealer took the sled and checked to offset and center to center. All was good.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Belt is cold? LOL....I dont think I have heard that one yet.
But the more yammie hears about blown belts the better we will all be.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I heard exactly this cold belt theory from my dealer who said they got the info from Yamaha.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Your belt is not frickin cold if you have been running it most of the day!
- 11K
