Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Will report back when I have an update from the dealer.
2017 LTX-LE. Approx 12 belts in 2000 miles. Blew first belt at about 3-400 miles. Clutches have always ran very hot and are peeling the belts apart. I've tried:
-stock clutching
-aftermarket clutch components
-updated secondary rollers (Got rid of flat spots)
-replaced 1 primary roller bushing that wore
-adding a shim behind secondary
-removing all shims behind secondary
-breaking in belts 25+ miles
-8JP
-8DN
-Ultimax
-straight edges, calipers, micrometers, parallels, indicators
-different belt deflections (belt height in secondary)
-keeping clutches clean & working/moving freely
I don't have a lot of faith in my dealers tech, he told me today that he hasn't heard of any winders with this problem. So that's why I'm posting this info, in case anyone has anything at all that will help.
-stock clutching
-8JP
-8DN
-Ultimax
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Wow, man thats crazy.... I'm up to 3000km with stock belt.
Hope they fix it! Yamaha rep should step in.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I had major issues like you. Blowing belts. Not as many as you have.
My dealer replaced the stationary halfs of both clutches this summer. Other then that you have tried everything.
Soupy
- Jan 10, 2017
- West Michigan
How do you ride it? How hot are the clutches?Wow, man thats crazy.... I'm up to 3000km with stock belt.
Soupy
- Jan 10, 2017
- West Michigan
What was the reason for replacing them?I had major issues like you. Blowing belts. Not as many as you have.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
BS. It may not be an epidemic, but there are enough people that have had belt issues to make note of it.
Hopefully, they take care of you and it gets figured out.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
The primary was damaged from one of the blown belts.What was the reason for replacing them?
Secodonary had marks on it where the helix was hitting he inner sheave.
I will try to find some pics
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
When I start my ride I always go easy to warm up my belt, maybe first 10-15 minutes then I ride normally fast lol.
fourload
Me too. I also break them in nice and easy.When I start my ride I always go easy to warm up my belt, maybe first 10-15 minutes then I ride normally fast lol.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
I do it every time I head out... always have, always will!Me too. I also break them in nice and easy.
78srx02
Following...
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
I have blown one belt at approx 700km
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
A buddy just got a 17 dx 137, and the belt blew at 100 miles. He said it didn't feel right, as if flat spotted, so while slowing from 110 + to let his friend on a cat turbo (zookie) catch up, it blew.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
What is the secondary set at? I had to crank mine up 10 degrees from stock or it would slip the belts real bad and they would blow at about 400 miles. Now I just change them around 1200 miles and they don't look bad.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
The 8DN is an apex belt. How can that be tried? Isn't it a lot shorter (or longer, I forgot without looking, but they aren't close)Will report back when I have an update from the dealer.
-stock clutching
-8JP
-8DN
-Ultimax
8JP is the oem viper/sw belt
8DN is the oem most every other yammy
The 17641 number is the same on both so it must mean 'belt"...lol
- 14K
- 8K
- 32K
- 10K
