elyislander
- Dec 13, 2009
I have been having the same problems with cold starting/idling as canadianhunter, rage, and bradford, on my 07 venture. The crappy idling and stalling occurs only after the temp light goes off and ends up idling ok after the sled is fully warmed up.
Does anybody know what the electronic control system is doing after this light goes off? Sled runs markedly different after the light goes off. Is the timing advanced or retarded electronically? If so I think the cam chain may be off. My tensioner was updated in 2008 before I owned the sled, I have confirmed it has the blue dot.
Thanks!
Thanks!
elyislander
- Dec 13, 2009
Or are the electric carb heaters shutting off as the coolant temp comes up to heat the carbs? anyone know the ins and outs of how this works?
yamascoot
- Feb 18, 2011
elyislander said:I have been having the same problems with cold starting/idling as canadianhunter, rage, and bradford, on my 07 venture. The crappy idling and stalling occurs only after the temp light goes off and ends up idling ok after the sled is fully warmed up.
How in the world could you do this job in 4 hours? I am an hour into it already and am staring at the handle bars and all of the wires and cables that will have to come off so I can get the bars out of the way to get the fuel tank out. I am never going to get all this stuff back together correctly...
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
You do not have to remove the bars to get the fuel tank off. You have to remove the seat, unbolt the tank, remove fuel lines and unplug sending unit. Then slide tank back.
Jfet
- Oct 30, 2011
Thank you! I got the tank off without removing the handlebars.
I do have maybe a slight problem when I get to the reassembly part. My rear muffler came out a bit more than an inch...it came all the way out (see picture).
I guess that clamp wasn't very tight :-(
What would you do to get it back together? Just cram it back in there and fish for the end of the mating pipe, or drill out the 5 rivets in the panel near the back of the snowmobile so I can reclamp the muffler...maybe replace the rivets with captive screws or something?
Handy
- May 12, 2005
- Anola Manitoba
Your muffler should slip back onto the header without too much trouble. Be carefull not to damage the edge of the exhaust pipe sleeve. I have taken a trailer hitch ball & carefully tapped it into the end of the pipe to give the gasket a bit of a lead in. Do your line up from inside the tunnel.
Jfet
- Oct 30, 2011
Handy said:Your muffler should slip back onto the header without too much trouble. Be carefull not to damage the edge of the exhaust pipe sleeve. I have taken a trailer hitch ball & carefully tapped it into the end of the pipe to give the gasket a bit of a lead in. Do your line up from inside the tunnel.
Yes, thanks. It was a lot easier than I thought because there is a rubber plug right where the two pipes join together that you can remove to tighten the coupling. No need to drill out anything.
The tensioner was a pain the in ###. The old paper gasket was severely stuck on, and I do not have little hands. Lots of WD40 and plastic scraper finally got the old gasket off.
Jfet
- Oct 30, 2011
A big thanks again to grizztracks for all of the pictures and info.
I got my 2006 Rage tensioner replaced (along with the exhaust donuts) and everything is back together and runs great.
Compared to fixing the problem bearing in the Diamond Drive on my Arctic Cat though, this job was a beast.
I did a lot of extra things while I had the machine apart (grease steering bearings, etc) but all in all the job took me about 16 hours...meaning I think I will keep my day job. Still, it was great to get to know the machine a bit better.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Glad to help out. I have two 06 Vectors in the garage now waiting for new tensioners. I'll do both in a day but I've done this a few times.
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
I'll be doing a 2006 Rage this weekend
thank you for all the great info !!!!!
BigDog05
Started to hear the chain tensioner noise at the end of my trip to the UP a couple of weeks ago. Sled has 2596 miles. Put 1500 miles on the sled in the UP and it ran fine.
I have the sled apart except for taking the old tensioner out. My problem is that the cam gears and the timing marks won't line up as described. When I line up the marks on the gears, I have to go approx. 1-2 mm past the two slash marks on the flywheel.
Looks like the engine is one tooth off, but I know it is not, because engine has never been open and it starts and runs fine.
My concern is: when I put the new tensioner in, should the marks on the flywheel line up as they look now or will they line up in between the two slash marks?
Chain seems tight, but could a bad tensioner case the marks to be that far off?
Pictures are what it looks like.
canadianhunter
grizztracks can likely give you the correct answer.
Anyway when the dealer did my 2 Rage's I felt that they did not idle as well and needed more warmup. Drove them approx. 2000miles like that. Power and fuel mileage seemed OK. After some grizztracks posts lifted the valve covers and they were both off. Chain had jumped one tooth when dealer did them. Took them back to dealer, he put them back in time and idle and warmup were back to original.
Sounds to me like yours may have slipped a tooth. Your lucky cause if it slipped more the engine would have been distroyed.
BigDog05
The old tensioner has not been removed yet. This is now the sled has run for 2596 miles.
- 32K
- 24K
