Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I checked mine. SJ and I bought from the same dealer. Mine had a lightly oiled filter but it wasn't excessive. No dripping anywhere. I'm guessing the guy that did SJ's got a little carried away. Like I said already, with the issues I had with my Mach Z, I'm pleased to see an oiled foam filter.
All the Prototypes at Milwaukee the filters were oily but it was definitly not the sticky filter type oil it may have just been engine oil.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
My concern is under higher boost..there is a significant vacuum...and it being drawn in and coating a sensor
Pstn head
So would it be better left dry ?
Official PDI and Setup instructions from Yamaha says nothing about oiling the filter.So would it be better left dry ?
Pstn head
Thanks that's good to know.
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
At the Yami dealer today, I checked the air filter. It was oiled. However, not with a yellow sticky substance. The techs there said they see some of the units come in (side by sides and bikes and sleds) with that yellow oil sprayed on them. The thought was to prevent corrosion. Someone may have been over exuberant with the spray on that unit.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Prevent corrosion of what..a plastic basket with a foam filter?
Who the hell is spraying these..the dealer or cat?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
They come with some sort of "oil" on them, it's NOT the same thing as Yamaha air filter oil, which is blue in color.
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
The dealer has received units FROM the manufacturer with metallic parts coated with that yellow sticky oil like substance.
The stock air filter on the SW is coated in a non-blue and non-yellow oil. I touched the filter and it appeared like a 10W-30 on my hand.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
since nothing in the pdi and manual talks about filter oil...AND my cat turbos came and ran with non oiled filters...I see no reason to keep whatever that crap is on it...I washed mine (removed basket from filter) thoroughly and air dried.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the belt dust theory makes sense...more reason to run a 8dn!
for those who want to not run it oiled...I removed...remove the filter media from the basket backing....I used dawn dish soap solution , but you can use filter cleaner ....let thoroughly air dry before returning
Filter is meant to be dry per Tech Update
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Interesting..another thing I wasn't wrong on per the boo birds lol
Yes you were correct now let's just hope the oil does NOT reappear on a dry filter.Interesting..another thing I wasn't wrong on per the boo birds lol
- 11K
