- Apr 14, 2003
- Hessel, Michigan
Putting weight in certain areas of the weight will add or decrease engine braking. I like to keep most of my added weight to the tips of my weights for less engine braking. (weight on the tips more equals shifting faster and holding the weights out longer).
Profile of the weights is critical also, plus what springs to go along with the weights. Less spring with heavy weights will make engagement very low and engine braking is basically gone. Use a stiffer primary spring and less weight in the primary clutch and your primary will have all kinds of engine braking.
@jonlafon1 - What primary spring are you running now? How are your weights set up?
I Asked the tuners last year in a thread about tuning more engine breaking into a flash, but it never gained any traction. I'm sure if there was enough demand for it they would get it done. Maybe just start up a new thread directed to the tuners and see how much interest there actually is
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Hey Nos, Heavy hitter 58.3 base> running 5.0 grams tip. .9 grams middle. 3.3 grams heel. Yamaha yellow/green/yellow spring. 911 cover. Glide washers. Straight 38 helix. Ulmer rollers. Eco trail tunePutting weight in certain areas of the weight will add or decrease engine braking. I like to keep most of my added weight to the tips of my weights for less engine braking. (weight on the tips more equals shifting faster and holding the weights out longer).
- Apr 14, 2003
- Hessel, Michigan
Thanks bud
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
- Apr 14, 2003
- Hessel, Michigan
the 63 gr seem loaded more at the tip already???
yes
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Anytime! I have not been on as much as last year. But I still read a lot of posts. Really happy with this Sidewinder. Hope you have a good safe riding season.Thanks bud
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
SJ not sure 63 gr. Are you speaking of the next heavier set of heavy hitter weights? Thanksthe 63 gr seem loaded more at the tip already???
fourload
I really like my TPI orange secondary, orange primary, glide washer, TPI roller setup with the stock weights running @ 8900. Great backshift and not much belt dust with this setup and have seen 122 on the speedo on the lake. The stock setup on my friend's 50th seems very lazy in comparison and will not run quite as fast on the big end(118 speedo) I finger walk him above 110. His rpm's are about 8600 which is probably the difference on top end. As soon as I break in and hit 9000 or more I will switch to the heavy hitters.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Are you all stock?I really like my TPI orange secondary, orange primary, glide washer, TPI roller setup with the stock weights running @ 8900. Great backshift and not much belt dust with this setup and have seen 122 on the speedo on the lake. The stock setup on my friend's 50th seems very lazy in comparison and will not run quite as fast on the big end(118 speedo) I finger walk him above 110. His rpm's are about 8600 which is probably the difference on top end. As soon as I break in and hit 9000 or more I will switch to the heavy hitters.
- Apr 14, 2003
- Hessel, Michigan
You too bud
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Interesting.....I run orange TP and a 33/35 currently and stock primary setup last weekend, and the EB was NON existent.More helix angle and the Orange thunder secondary spring and you will damn near go over the bars if you completely let off throttle. I found myself having to almost ease off the flipper as It would back shift like crazy. Conditions surely played into this some also as the base was thin. In five hundred miles(ONLY thing different then my end of year set up was Thunder orange secondary spring) I might have used the brake 3 times.
Sitting at 3100 at this point
Not sure the weights are the factor.. I run the thunder weights, and eco trail tune.
I need more for sure...hate using brakes.
Hoping my STMs and dalton spring will get me some EB....
Dan
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Dan, you will find it. I have read a lot of your posts. Which takes time! Your going to have to play with clutching,and your a details guy. Don't sweat it. I have set up listed and feel it back shifts like crazy. I know it sounds crazy. But I feel it's the helix and weight placement on the heavy hitters. More angle means less back shift traditionally correct? I don't have a clutching book. I go by my speedo and butt feel. So not sure I have it right all the time.Interesting.....I run orange TP and a 33/35 currently and stock primary setup last weekend, and the EB was NON existent.
Dan
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Running 8 DN belt. Turbo force can, eco trail tune. TDHey Nos, Heavy hitter 58.3 base> running 5.0 grams tip. .9 grams middle. 3.3 grams heel. Yamaha yellow/green/yellow spring. 911 cover. Glide washers. Straight 38 helix. Ulmer rollers. Eco trail tune
Sled engages at 2800. Pulls 9170 on the punch. Settles in around 8750-8900 on top. Seen 129 speedo on plowed road. Low 120 trails. Depending conditions
- 21K
- 37K
- 31K
- 6K
