DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
These guys are supposed to be coming up to our track this year.I think he had a speed track? If so can be doable on good ice and a cold day. And a bit of a tail wind helps allot .
1" hacksaw cut to .5".
Trailleader
He cut the lugs on the track
NYTurbo
DMC
Do u shave your ice ?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Lot's of magic in that Yomama sled, and what I really like is the sharing of knowledge going around with this group that does it just for the fun factor with friends! Low sled, low seat, speed track, 330 hp on race fuel, gearing, drivers, fuel pump, regulator, HEADER, and more! Even the carbide set up on skis, or windshield choice, or perfect ice with no snow dust, all add to that top speed! And yes Wind for sure, can take or give MPH!
Getting a stock 998 motor/turbo set up, to run 140mph in 1320' doesn't look like an easy quest! But what a WOW factor...
DMCTurbo
- Nov 12, 2005
No just plowed. You should make a trip our way this winter.DMC
NYTurbo
It doesn’t get rough or wavy ?No just plowed.
We get maybe 2 weeks of good ice then it gets too wavy.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
No way! Lol....that's cool. I've been following him, he definitely does some sketchy s***. He's got a yami 1000 in a golf cart,These guys are supposed to be coming up to our track this year.
And I can tell by the operation he's not rich or fully funded. He just tries to make the best of it.
Look at the way it comes across for god sakes. Hahaha...
DMCTurbo
- Nov 12, 2005
They have a drag they cut it with. It has grader blades on it. It doesn't give you that NBSSR surface but it keeps it flat.It doesn’t get rough or wavy ?
Trailleader
Didn’t hypersports go 146 in 1000 ft with stock turbo 998 few years ago
Doc Harley
- Oct 17, 2016
- Here & there
Currant weights..as of 12/27/2023
number1kyster
So let me get this straight. Last year, they weighed a 850 Renegade XRS at 651lbs, ready to ride.
This year, the 900 XRS weighs 630lbs and the 850 comp turbo weighs 615lbs?
earthling
The comp r doesn't have smart shocks or a battery. Put those back on and they weigh the same as last years model + a bit. Cannot explain the 900 as the published dry weight of the 900 is 52lbs more than the 850.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Derek I would have liked to see your sled run at NBSSR on good ice. I ran 135.? On max spool 17 once on a super cold day (only once lol) . As good as the track is at times at Whitsone it’s not Perfect.No just plowed. You should make a trip our way this winter.
0degC
- Jun 5, 2009
- Sudbury, Ontario
Great I’ll try not to miss this.!These guys are supposed to be coming up to our track this year.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Yeah something is weird with their numbers. The 900xrs also had smart shocks too. So a 23 850 XRS with smart shocks is 21lbs heavier than a 24 900R?! Is Gen5 that much lighter?So let me get this straight. Last year, they weighed a 850 Renegade XRS at 651lbs, ready to ride.
Notice they didn’t have a winder this year. Would have also liked to see a lynx weight.
- 9K
