Mighty
 - Apr 17, 2003
 - Grand Ledge Michigan USA!
 - 22 Mach Z
23 Sidewinder SRX
Can you get your hands on a true decibel meter?  I wouldn't trust a smart phone app to be very accurate.
		farmerschiferl
 - Dec 28, 2010
 - Hewitt,WI 54441
 - 2017 Yamaha Sidewinder BTX-LE
 - Hewitt, WI
i believe he has the local dnr agent comeing out to verify the levalsCan you get your hands on a true decibel meter? I wouldn't trust a smart phone app to be very accurate.
Mighty
 - Apr 17, 2003
 - 22 Mach Z
23 Sidewinder SRX
Cool. I missed that. Thanks.i believe he has the local dnr agent comeing out to verify the levals
 - Apr 14, 2003
 - Hessel, Michigan
Mighty, I have a decibel meter (calibrated) at work right now that I use for machines. I tested this against my smart phone app and was pretty close....but as mentioned, I want the final word from the Wi DNR Agent.
swampcat
 - Mar 17, 2014
 - N. E. Wi.
 - 2020 S W LTX-GT
Cant get any more OFFICIAL than that. Imagine EVOs selling power with a DNR endorsement, I mean come on, the Cubs did win the world series.Mighty, I have a decibel meter (calibrated) at work right now that I use for machines. I tested this against my smart phone app and was pretty close....but as mentioned, I want the final word from the Wi DNR Agent.
		kylechargerrt
 - Dec 8, 2013
 - Scotland Ontario
 - 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Looks sneaky enough behind the factory heat shield that it just might fly in Ontario.  Will this be the quiestest muffler that evo will offer?
			snowbeast
 - E waterboro,maine
- yes
- YOUTUBE
 - yes
Copied this from EVO's post where they are testing and dynoing the Sidewinder. Stopped by Jim last weekend and saw his Magnum Muffler for the Sidewinder. Told me to take the Magnum and do some decibel testing to see if the Magnum Muffler creates HPR and is still trail friendly....The answer is YES!!!! Great job once again EVO!
Videos are on my FB page right now if you are friends with me. There are 2 stock videos showing idle, rev to 2,800 engagement and a couple throttle hits on the grass....and 2 videos with the Magnum Muffler at idle and a couple hits on the grass.....all while my sound meter is in view of the camera.
My decibel meter showed 83-84 decibels at the recommended 13.1 ft. I have a DNR Agent coming to my house to verify those readings late this week or early next week, but is definitely within the 88 decibel limit. This Magnum should be very close to production....but what you see here is still prototype as it is the first muffler built. The sound, decibel readings will stay the same....but some brackets may be changed.
Plus, this Magnum muffler has all of the mounts for the heat shields to be put back in place
EVO's post....
Here is a picture of our 304 Stainless, TIG welded "Magnum" Quiet exhaust for the Sidewinder/Thundercat. The dyno gains were the same as our bullet, so + 10-11 hp. It saves about 5 lbs over the OEM and has a nice deep tone without being loud. Our exhausts are 100% made in the USA of 304 Stainless and TIG welded. We manufacture our own exhaust cans - rather than buy an off the shelf car muffler - they are custom made for each application so they fit in the space available. Both our Bullet and Magnum exhausts utilize the factory heat shields and use all of the OEM supports. For those who don't know, adding an exhaust does not raise the boost pressure of the OEM tune. The ECU targets a very specific value and if it is deviated from even slightly, the ecu will correct for it. Tuning is going very well and if the weather cooperates, we should be on snow testing in 2 weeks.
snowbeast
 - E waterboro,maine
- yes
- YOUTUBE
 - yes
does your bullet muffler give you more room to service chaincase adjustment bolt,looks like the super quiet can still hides access to bolt,am I correct,or can we still get to bole,and does bullet can have more hp vrs quiet can,also prices please.
 - Apr 14, 2003
 - Hessel, Michigan
Looks sneaky enough behind the factory heat shield that it just might fly in Ontario. Will this be the quietest muffler that evo will offer?
Yes, the Magnum is the quietest muffler.....But they also sell the Bullet muffler which is targeted for racers and guys in the mountains.
I will let Jim @EVO 1 give you the specifics.....but I can easily get to the chaincase adjuster bolt. Hpr was said to be about the same between the 2 mufflers, Bullet and Magnum.
 - Apr 14, 2003
 - Hessel, Michigan
Confirmed....3:15 pm appointment this Monday with Wi DNR to verify sound test on the EVO Magnum Muffler.
		sxr70001
 - Dec 4, 2010
 - Michigan
 - Sidewinder LTX SE
SR Viper RTX SE
I just watched your videos.  You can just tell that sled wants to go!  It's going to be an exciting season for sure.  I'm thinking in a year or so I will just quietly switch my viper for a sidewinder and my wife wont even know the difference.   They're in the garage up north she never looks in there.
  It will have to be blue of course.
Thanks for all you do for this site.
		jonlafon1
 - Aug 18, 2014
 - 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Cool. What are we looking at as far as test parameters? WI is 88 db at what 13 feet? Idle and then you rev it up or what? Put sled on stand? Thanks for the Info. Curious how they test in the fieldConfirmed....3:15 pm appointment this Monday with Wi DNR to verify sound test on the EVO Magnum Muffler.
 - Apr 14, 2003
 - Hessel, Michigan
I just watched your videos. You can just tell that sled wants to go! It's going to be an exciting season for sure. I'm thinking in a year or so I will just quietly switch my viper for a sidewinder and my wife wont even know the difference. They're in the garage up north she never looks in there.It will have to be blue of course.
Thanks bud!
Bigbluemachine
 - Apr 20, 2006
 - NY
 - 2017 Sidewinder RTX LE
2011 Apex ER
There is no other color for me.I just watched your videos. You can just tell that sled wants to go! It's going to be an exciting season for sure. I'm thinking in a year or so I will just quietly switch my viper for a sidewinder and my wife wont even know the difference. They're in the garage up north she never looks in there.It will have to be blue of course.
 - Apr 14, 2003
 - Hessel, Michigan
Every state is different.... Wisconsin is 88 decibels at 13.1 feet and that is at idle.
This was in Michigan last year when they were trail side and we were all checked. The piped Polaris in our group got a hefty fine...Think is was $250?
 - 8K
 - 50K
 - 14K
 - 6K
