SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
I had mine ice up pretty bad. Was up in Quebec for 7 days really cold, minus 20 F. Actually had solid ice covering the hole in the running board under my right toe.
Lots of snow dust and a few runs in powder. Checked a few times and the hose had ice built up around it, and almost closed off.
I just did what theewarrior did and re-routed the hose to the chain case.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I was thinking exact same spot....keeping it out of the snowstream and in where its warm. It will drip out of that hole where you tighten the bottom screw for chaincase.I had mine ice up pretty bad. Was up in Quebec for 7 days really cold, minus 20 F. Actually had solid ice covering the hole in the running board under my right toe.
Also cutting the end on a angled cut helps, making the opening elongated and larger, harder to freeze.
Only reason I held off on that spot as its now tough to know if your chaincase is leaking as that area will always have oil laying in it.
Dan
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I know it’s likely already been discussed but 25 pgs is a lot off scrolling lol. What’s the issue with just removing or bypassing the valve and retaining the stock plumbing which vents back to the intake? Apexes and Nytros all vented back to the intake I believe. They ran thousands of miles with no issues.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I think there are a few who are doing this and it's probably a very good option.I know it’s likely already been discussed but 25 pgs is a lot off scrolling lol. What’s the issue with just removing or bypassing the valve and retaining the stock plumbing which vents back to the intake? Apexes and Nytros all vented back to the intake I believe. They ran thousands of miles with no issues.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
You mean sending all the vapors back into intake? Most of us dont want that. It will fill up the charge tubes and intercooler and need to be drained or performance will go down.I know it’s likely already been discussed but 25 pgs is a lot off scrolling lol. What’s the issue with just removing or bypassing the valve and retaining the stock plumbing which vents back to the intake? Apexes and Nytros all vented back to the intake I believe. They ran thousands of miles with no issues.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Ok I didn’t realize there was that much oil coming out. My apex and Nytro didn’t seem to accumulate any oil in the air box so figured these would be similar.You mean sending all the vapors back into intake? Most of us dont want that. It will fill up the charge tubes and intercooler and need to be drained or performance will go down.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
Similar, but no turbo to ingest the residue.Ok I didn’t realize there was that much oil coming out. My apex and Nytro didn’t seem to accumulate any oil in the air box so figured these would be similar.
1st.yammy
- Jan 7, 2018
- Saratoga, NY.
- 17 sidewinder ltx-DX 137
I just added this 5 psi pressure relief in the by-pass hose in case it freezes over at the end of the hose.
**sj**
I just added this 5 psi pressure relief in the by-pass hose in case it freezes over at the end of the hose. View attachment 137542
Nice idea but couldn't that relief valve freeze also?
1st.yammy
- Jan 7, 2018
- Saratoga, NY.
Anything is possible. It was just thought i had and Hopfully it's not needed but I figured I'd just throw it in there and see what happens.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
i ran it this way for hundreds of miles. Actually not a lot of residue in the belly pan area at all. I guess my ONLY concern was the oil going somewhere if tipped. I have since ran my hose to under foot right side. I do not run a loop. I understand the risk but I just don't off trail and in 3500 miles have never come close to tipping. Honestly in super cold temps running it to the under belly pan area isbest IMO. I just feel your odds are better with it under foot if tipped. But honestly the sled HAS two overflow hoses going into under belly pan area. It's the logical place in my mind. Especially with a loop in place. My 2 centsIm sure one could route the hose to the bellypan below engine, and just let it drip into the pan, it surely would not freeze there but would be messy id think.
I just keep eye on mine and its never froze up, can always just tap on it to break off any ice on end.....likely a combination of deeper power and not enough speed to make heat in the vapors. Starting and stopping alot allowing ice to build up..... Also the routing is important, I have mine tight to oil tank so its warm area....
Maybe Hasselhoff should post pics.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
A 1 inch vertical slit a few inches upward is best solution if you somehow got a frozen tip.....
I think if you cut the end so it's angled and rearward its very hard for it to freeze, as mine has not had issue.
POWERHAULIC
The angle cut works perfect. Did this for years on carb vent tubes to prevent icing.A 1 inch vertical slit a few inches upward is best solution if you somehow got a frozen tip.....
SUC_doo
- Jan 4, 2017
- Collingwood, Nova Scotia
- 17 sidewinder rtx, 08 apex ltx gt, 01 formula deluxe
Why can't you use remove the innards of the valve so it won't work =, now acting like an apex with no roll over valve? .....This has so many pages now its crazy,,,,,So we all have this hose coming out at the bottom of our sleds? Wat did you do with yours dan
theewarrior
Half the reason I think most are removing the valve is to eliminate the sludge people are getting built up in the intercooler
- 45K
