I've hated these chaincases ever since the day I had to walk home on only my second ride out last year!
Bigtime weak point on an otherwise awesome sled.
yamaha06
Has anyone ever added any extra silicone around there sight glass to help with holding it in place? Mine seems like it is in there pretty good but was just reading about people having issues with them falling inside the chaincase.
The sight glass on my 18 fell into the case second ride last year! When I put the new one in, I added a little grey gasket maker.Has anyone ever added any extra silicone around there sight glass to help with holding it in place? Mine seems like it is in there pretty good but was just reading about people having issues with them falling inside the chaincase.
yamaha06
Ya mine hasn't fallen out yet but I was thinking of adding some to prevent that. Did you add it to the outside or the inside of the chaincase?
Just a light film before I installed it, and a little more on the inside after I installed it, I didn't want any to be seen. I'd have to think that the sight glass wasn't pushed in all the way at the factory.Ya mine hasn't fallen out yet but I was thinking of adding some to prevent that. Did you add it to the outside or the inside of the chaincase?
Update. I got the new one. Very tight and lots of Loctite. No way its going to come loose.
I can confirm this also with new Tensioner. They knew. God Dang becoming X-Files around here and the darn Little Green Men at Cat have taken to Sabotage!2019 Srx's have green loctite on the roller bolts just confirmed on my sled at the dealer
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
Update. I got the new one. Very tight and lots of Loctite. No way its going to come loose.View attachment 143301
Do you know when the updated part came out? I have an '18 and trying to decide if I should take the chaincase back apart to check this (already changed the oil) before this season or just wait until next winter and do it then. Already changed the engine oil too... so, really not looking for a "make work" project but will do it if it's been an issue on the 18's. Thanks
I do not but the 01 is definitely new. Not sure of any way of knowing actual date of change. Will ask parts guy at dealer if I get a chance.Do you know when the updated part came out? I have an '18 and trying to decide if I should take the chaincase back apart to check this (already changed the oil) before this season or just wait until next winter and do it then. Already changed the engine oil too... so, really not looking for a "make work" project but will do it if it's been an issue on the 18's. Thanks
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
My 2017 Winder has green loc-tite on it. I redid it with red.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Took mine apart yesterday... Bots are tight with 3000 miles... Left them alone and reassembled..... Fingers crossed...
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
So what is the verdict on this? Is it random sleds that have no loc tite on the screws? Seems random as some are good and some loose?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Just wondering why the red instead of green? Not saying you did anything wrong just wondering?My 2017 Winder has green loc-tite on it. I redid it with red.
yamaha06
Mine also had green loctite on them, but were prettt easy to remove. I cleaned them up and re-installed with red.
