- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
**Update**
Belt blower #1
Going to try locking down the secondary today
After trying that, going to switch to a previous style primary as for how many belts this thing has blown in the last month (almost up to 10 belts now), the SW primary is not looking good. The cast tower scallops are bent over and the clutch is starting to stick.
Belt blower #1
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
**Update**
Belt blower #1
Been there done that. If the clutch is sticking its done. Time for the old style Apex clutch and like you said then lock the secondary down. I found I have to lock the secondary down. If it floats out like mine does, (because I use shims inside the secondary for belt deflection) and it just freely floats outward doing this, it it's put under power, the secondary does not move inward until you let off the power, I don't care how well it is greased and moves while just sitting there. Try it on the stand with the brake on or track dyno and you will see what I'm talking about. The secondary stays stuck outward, it does not move inward like it is supposed to.
Now if you still float like the stock sled does using shims or a deflection adjuster against the helix, where the helix pushes the secondary into position at low speed or idle, this does no seem to be as big an issue. It's already against the inside bearing as you apply power so it never gets time to actually float out while under power. IMO its best to just lock them into position so they line up at full shift.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Can you and is it advisable to lock it down when using a belt deflection device.
KnappAttack
- Feb 19, 2004
- Welch MN
It can be done yes. If it were my sled I would do it yes.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
What is "locking down secondary"?
Sorry I'm poor in english..
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Setting up secondary to run with no float
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
And what is the best way to lock it down?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
**Update**
Belt blower #1
Original clutch is on my bench and the rollers are completely stuck. The clutch needs major help....
Sled has Apex (previous style) clutch now installed.
No phone calls yet, so just waiting to hear back.
Belt blower #1
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
**Update 2/15/21**
All belt blowers, #2 on on.... are not having issues anymore and with more miles on everyday/weekend, they are on the same belt after the 57.5-58mm offset change.
Belt blower #1 is back in my shop. Not a belt blower anymore....but the belt is hitting something as the belt is trimming the top cogs off on one edge. See pic
KnappAttack
- Feb 19, 2004
- Welch MN
**Update 2/15/21**
Yes it is. Possible its ballooning into the clutch guard or something? So what if you just wrap up the secondary spring tighter to eliminate the ballooning? I tested one of your orange secondary springs on my drill press scale in the winder secondary, and ended up putting more wrap on it then you guys were recommending by quite a bit, no adverse effects at all, just need to adjust clutching a bit for the tighter wrap. It gets rid of the whip and ballooning of the belt, backshifts better and keeps a better hold on the belt. I saw no loss in speed or ET either so really a win win what I see.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Depends on the riding the user does and which weights they use make a difference. Also watching belt temps.
Most of our customers should be running 3-2 with our orange secondary spring.
Yes, going to check everywhere for ballooning of his belt.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The best top mph i have gotten on trail is with the secondary orange spring.
I think it has more to do with 200-300HPthis thread should not even exist,fix the root cause of the problem and its not machining anything!!Quality Control!!!
fourload
Mike, How stiff is the orange spring on your press compared to the stock or Dalton B/O? I have always had great luck with the thunder spring from 40-60 degrees of wrap. I have used it stock, with Powertrail SM and now MS 16. I am currently liking 60 with the MS 16 SM tune with a 35 helix and xs belt. Also have never blown a belt even when offset was set at 60mm (now 57.8)from factory and used the JP belt with stock motor. I live on a 31 mile lake and do make many long high speed runs.Yes it is. Possible its ballooning into the clutch guard or something? So what if you just wrap up the secondary spring tighter to eliminate the ballooning? I tested one of your orange secondary springs on my drill press scale in the winder secondary, and ended up putting more wrap on it then you guys were recommending by quite a bit, no adverse effects at all, just need to adjust clutching a bit for the tighter wrap. It gets rid of the whip and ballooning of the belt, backshifts better and keeps a better hold on the belt. I saw no loss in speed or ET either so really a win win what I see.
- 9K
- 12K
