snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
So far I’ve put new skis on my 12 apex xtx so there’s that … o and a taller riser
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
The updated lower driveshaft repair kit is a must on a new or used sidewinder.The updated bearing has a collar that is pressed in to the bearing I.D. and has 3 Allen screws to lock to the lower shaft.$160, this should be added to the list of fixes.They are available @ Barn of Parts,or call Travis during buisness hours @717-821-9639
Dave385
- Nov 12, 2017
- Michigan
- 2018 Yamaha Sidewinder
2008 F1000
2007 F1000
2007 F1000
- Lapeer Michigan
Another GREAT Design from Travis at Barn Of Parts!!!! https://barnofparts.com/The updated lower driveshaft repair kit is a must on a new or used sidewinder.The updated bearing has a collar that is pressed in to the bearing I.D. and has 3 Allen screws to lock to the lower shaft.$160, this should be added to the list of fixes.They are available @ Barn of Parts,or call Travis during buisness hours @717-821-9639
Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2025 SRX
- Sledding Location - Fenelon Falls, ON
Is this applicable to the Thundercats as well?The updated lower driveshaft repair kit is a must on a new or used sidewinder.The updated bearing has a collar that is pressed in to the bearing I.D. and has 3 Allen screws to lock to the lower shaft.$160, this should be added to the list of fixes.They are available @ Barn of Parts,or call Travis during buisness hours @717-821-9639
- Feb 13, 2017
- Amston,CT
Yes,thread #19 has all necessary info for a long term fixIs this applicable to the Thundercats as well?
Derek Fosbury
- Jan 18, 2021
2025 SRX
Thanks!
stgdz
- Mar 27, 2021
- Buffalo MN
Yxz engine rebuild videos. Very similar to 998
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Vid of the list on #1 post
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
It sure would be nice if Cat takes care of some of the known problems that have been around since 2017. 20,000 grand spent on a sled that needs to be torn apart when brand new to make it reliable is getting ludicrous!
- 53K
- 222K
