putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Is this a free ecu update?
Yes
Motorboat
First ride tonight on new flash. Started 1st try at 11 degrees F. Very snappy. Rode 57 miles. Rode hard for last 25 miles. Stopped to top off and it started up 1st try hot. Its 5 degrees now so I will see in the morning how it cold starts. My start issues started at -5. I am very happy and fingers are crossed.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Cannondale, have you made any top speed runs with your new flash yet? The consensus seems to be the flash makes the sled feel more responsive, correct?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Anyone running the common Trail Can + Airbox mod with the new flash?
Mine does not have the pulsing at idle anymore!
Not yet. Will this weekend but I also clutched since New Years ride (last years flash)where I hit 107gps at 8400rpm. So was 400 rpm down from last year with my off season changes.Cannondale, have you made any top speed runs with your new flash yet? The consensus seems to be the flash makes the sled feel more responsive, correct?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Wow! What gearing? Drivers?
25-45 9 tooth driversWow! What gearing? Drivers?
MtCooler believes the popping and running on 1 or 2 cylinders was not faulty tether but was when idled long and temp reached over 200deg. No warning light. So don’t do that with new flash.
rbell14
215 miles today in Munising and this flash is worse than what I had. Sled is in a 2 start situation most of the time. Never had that before this flash. Rarely did it start on first try even when I let fuel pump cycle or not. first try and it putters and cranks but doesn't start. Let go of key, hit it again and it fires instantly.
Very up disappointed with this flash, we all expected more. It's like Yamaha has to provide us with a manual on how to start this damn thing???
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Mines doing the same thing215 miles today in Munising and this flash is worse than what I had. Sled is in a 2 start situation most of the time. Never had that before this flash. Rarely did it start on first try even when I let fuel pump cycle or not. first try and it putters and cranks but doesn't start. Let go of key, hit it again and it fires instantly.
Cruicker
Try giving it a shot of throttle when it is cranking on the first time. Mine fires when I do this. I have a changed my battery, plugs to iridium new high test fuel with isopropyl and still the sma thing is happening. I am blamong the flash and just going to ride it.215 miles today in Munising and this flash is worse than what I had. Sled is in a 2 start situation most of the time. Never had that before this flash. Rarely did it start on first try even when I let fuel pump cycle or not. first try and it putters and cranks but doesn't start. Let go of key, hit it again and it fires instantly.
Fixit156
- Feb 6, 2017
- Holliston MA
- 2017 Yamaha Viper RTX DX
Right now I’m in Millinocket ME. The temperature is-2 F. They are predicting the temperature is going to be -10 degrees. Will see home starts with the new flash
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I can't remember who gave me the voltage requirements for the ECU but the requirements do change from one manufacturer to another. Even the type and use of the ECU within the same manufacturer will change the voltage nominal required.Is that 9.8V spec listed somewhere? If so that is the problem right there. I wish my Multimeter had a faster refresh rate but It does have recall and cranking at -10*f usually shows ~9.5V and I assume even lower at colder temps. I'd like to see the inside of the ECM to see how big the caps are too, I'm guessing not enough capacity to smooth out the steep voltage drop during compression strokes. I have an EFI outboard engine that runs into the same issue, if the cranking voltage drops below 9.5V while cranking the ECU "resets" on every compression stroke. Installed a bigger battery in that boat and problem solved. If its going to be Frigid, it gets parked next to the truck as it will start very quickly when boosted off running pickup truck in the morning. Mine has never failed to start on Frigid mornings without a boost but I cringe at taking 2-3 long attempts before it catches.
Fixit156
- Feb 6, 2017
- Holliston MA
Just start my 2017 Viper with new flash started great outside temp -5 F
