They need to be sunk into the track flush.You think so? I used a torque wrench and tightened them to the woodys spec of 15'lbs or 180" lbs. should they be tighter?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
If not a little below flush imo.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
What torque spec do you guys use?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
None, tighten them up until they are slightly sunken.What torque spec do you guys use?
I basically do the same thing.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
If you use the 15 pound torque spec they will eventually start to pull out anyway.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Right on guys!! I'll tighten the sh!t out of them tonight and sink those bishes right down!!
i'll report back!!
thanks again!
i'll report back!!
thanks again!
Mototown
- Sep 11, 2018
- Apex 40 th
Can’t see it being studs , making that much noise pulling away that slow ??? Sounds like something is skipping??
I agree but its still a good idea to get those sunk. I think its the drivers.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
You’ll see
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
The studs, even sunken, will actually wear the drivers somewhat, then the noise will totally disappear.
Mototown
- Sep 11, 2018
- Apex 40 th
Unless you have the studs to close to the window, squishing the window closed , causing the track to pop into the drivers
AAD
- Dec 11, 2018
- SRX
Yes, studs are definitely not tight enough they need sunked in I went over mine and then drove a few miles and went over them all again both times with track warm inside the shop.
Track too tight will make some extra noise and same with the chain if it’s way loose or too tight.
AAD
- Dec 11, 2018
- SRX
Does have enough noise though you would think the studs where hitting the front cooler or top of tunnel
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yes it is extremely loud.......hey are those little pieces of aluminum is see flying through the air in the video?Does have enough noise though you would think the studs where hitting the front cooler or top of tunnel
- 16K
