OSP SR Viper belt adjuster with float
If I order now will I get the new batch with the deeper cup to make belt removal easier?
we have 2 sleds in the shop and we can use tool to remove belt its a bit tight but can be done.. I will make the cup deeper in the next batch to make it easier to remove belt..
I also tried to usr the srviper code last night and received the same message that the offer expired November 14th. I will place the order today if you will honor the discount offer.
Also same question as before. If I order now will I get one from the "next batch" that will have a deeper cup that makes it easier to remove the belt.
I am picking up my new Viper today and I need to start buying goodies for it. LOL!
I just placed my order. I was hoping for the earlier $55 deal but then realized that you had said 20% off which is exactly what I received with the discount code. Please make sure that you send me one from the new batch with the deeper cup to make belt removal easier. Thanks!
Hello Gentlemen
Will I be able to change over from 8JP and run the 8DN belt with onlyhaving to install this adjuster? I am going to order one as well! Looks Great!
On a side note! Is it True the 8DN belts run 10mph faster as stated in other posts?
Newbie Yamaha Owner!
Thanks I have placed my order!
So remove secondary, remove back plate and install adjuster is it in a nutshell? Is Yamaha belt height the same as my Skippy at 3/16" above?
Make sure you remove the 3 screws on the back side of secondary. The plate is between the 2 sheeves on the secondary that has three screws that need to be heated to remove as cannaondale mentioned.
