Real Clutch Temps Data
One other thing that might be influencing cool clutches. Frog skin vents. Only minor issue is you will get belt dust on your left ankle. Not seeing a lot of belt dust but some. I feel with the vent up front it pushes Some dust onto your left ankle area.
I will be looking into some venting this summer.
Those are Frogskins?
Yes. Pretty easy install. Drill the right size and stick. I bought a few extra just in case you get a WTF moment and punch a hole in them. They give dimensions of OD and such on the website. Only draw back and not a big issue IMO is blow through dust. But at 250 ish hp I really don't see any clutch set up not having any belt dust. Been drilling that front hole on the procross chassis since 2012. The location is tucked enough behind shock and blows right on belt. Never had any issue with anything but air going through. Good product and very good stick.
I will be testing this summer with Anemometer. (air flow tester)
I'm going to use a leaf blower & test getting some air to flow on both sides
Your frickin crazy, I can’t even spell analometer
Stop picking on me I’m special.
Well,my Dalton blk/org spring wrapped 6-1 on stock 35 helix,did not work well for me,except keep rpms around 9000,but on my stm ramps loaded up to 80 grms and ulmer pink primary,it blew my first and only belt. There was slippage,but none you could see,i mean no dirty black marks on either clutch,but I know what slippage sounds like,and what a grenaded belt sounds like at 110 speedo,lol not preety,i got lucky none of it got lodged into either clutch sheeve,but it does make primary clutch at towers look bad. It did run 115 gps early morning on hard packed snow,i had about 2/10,s of a mile to do it in,but it did seem to feel flat on top at that speed. I suspect some of the speed lose was because I did not have my scratchers down,and it was very hard,like ice and I had my track very tight,because it had been racheting some at top speeds. Ok so back to secondary,stm 38 now with ulmers red spring wrapped at 9-1 have not had a chance to test that combo let.
