snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
FYI - I just got 2 stock gears from country cat and they both have the 3 holes and the bushing is drilled all the way through.
theewarrior
Which 1.5 cat belt do you mean DanAgree Brother....after a season(2 total) now with these winders....Its becoming clear what setups will eat belts pretty much instantly. Big traction and tall gears while turned up over 270hp will pretty much take ANY belt out in a few miles when flipper is whacked. And for guys like me in tight trails, corner to corner the belt issues arise much faster the wide open trails.
Im pulling back on gearing(back to stock 21/41, but considering a 42 lower too for a 123gps top speed) which alone should help me. I also lowered my offset late last season hoping for some help there too.....Also going to run another Ultimax as the cat guys swear by them(similar to the 112 cat belt for life) and also going down to a slightly less steep helix to keep consistant tension down low on belt.
If this yr is not much better, I will slap a TEAM(cat) primary on for next yr which will allow the wide 1.5" cat belts then.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
great to hear.....I had just put mine back together too....GRRR.....Ill change it out next season I guess.FYI - I just got 2 stock gears from country cat and they both have the 3 holes and the bushing is drilled all the way through.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
The Ultimax for Cat is 1.5" and the Cat 104 & 112 are too.....Which 1.5 cat belt do you mean Dan
theewarrior
They’re not too long for the sidewinder I thought Cat belts were a bit longer?The Ultimax for Cat is 1.5" and the Cat 104 & 112 are too.....
theewarrior
And thank you DanThey’re not too long for the sidewinder I thought Cat belts were a bit longer?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
If you read my post, I was talking about a TEAM primary. Its the only way to run wide belts. A wider belt should be longer to fit our stock secondary, and likely would work out well. But I have never mocked one up so that remains to be seen. Probably the correct step would be to convert the secondary over to cat(TEAM) as well....That would need a Jshaft swap too though.They’re not too long for the sidewinder I thought Cat belts were a bit longer?
Id much rather get my YAM clutches to give me better belt life as its alot cheaper..lol .
Dan
theewarrior
Thanks I do have the 911 cover for running wider belts
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I thought 911 cover just dialed inward, and was not able to go outward.....so 911 allows for a 1.5"?Thanks I do have the 911 cover for running wider belts
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
You'd need to shim the spider wider by the difference in belt width to keep the weights untucked. If you didn't add shims behind the spider the weights would be tucked further and belt slip would be too great. Don't just go throwing on a wider belt and expect it to work.
theewarrior
I never measured for sure but I know when I put the cover on and a new stock belt I half to turn it in a fair bit so I’m pretty sure it will take wider belt for sureI thought 911 cover just dialed inward, and was not able to go outward.....so 911 allows for a 1.5"?
theewarrior
I will measure it tomorrow
Mototown
- Sep 11, 2018
- Apex 40 th
8jp belts on back order from Yamaha Canada hoping new belt that comes is 8jp -01 lol
theewarrior
Oh are they making a newer one?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Im done with stock dirty belts....grrrrr
Ultimax for me
Ultimax for me
