I can make a small wheel kit that will last as long as the sled buy are people willing to pay? Might be close to $60 a pair.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
I’d be interested in a kit to replace all 6 idler wheels in my SRX skid.
Rubber chunking is usually from studs. Especially at bend.
I will check into making this kit again. I made a few for the firecats that were also bad for wheel failures. They will last like I said and studs will have no affect on them.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
Is it possible to make a 'rubberless' design or do you build your kits with wheels that are premanufactured? That was probably the best benefit to the SlyDogs wheels - nothing to chunk or break off and ice/snow doesn't stick well to UHMW plastic.
Will be a solid plastic wheel but will have the thick rubber like from the 90's that dont come apart.Is it possible to make a 'rubberless' design or do you build your kits with wheels that are premanufactured? That was probably the best benefit to the SlyDogs wheels - nothing to chunk or break off and ice/snow doesn't stick well to UHMW plastic.
That would be awesome! Mine goes through the two by bend pretty much seasonally.Will be a solid plastic wheel but will have the thick rubber like from the 90's that dont come apart.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
I would be interested in replacing all of mine.Will be a solid plastic wheel but will have the thick rubber like from the 90's that dont come apart.
I have a 2018 Vector. Are these wheels the true good ones from Yamaha & not the yamacat ones that fall apart.
Got parts coming and will see what the costs will be to make it worth selling. Stay tuned!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Larson axle is the best, billet aluminum.
Got about $550 or more into that rear axle set up?View attachment 149363
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea i Think it was $280 for the axle kit then another $100 a piece for the outside wheels.Got about $550 or more into that rear axle set up?
But the axle is bulletproof! You could just run the wheels that come with it, they are solid.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I'm in.
My J&T kit is still tight after 7500 miles. OverFreakinKill bearings are still perfect.
Wheels look new & most know that i am NOT easy on anything.
It was the only thing that made it unscathed in my "Torn Tunnel of '18".
They are like the "Black Box"of the rear wheel world
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Can you make it bolt on with something other then the 6-32 screws used on it now?
- 16K
- 33K
