burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
982 miles on XTX SE. Original belt. All stock. Had some long WOT pulls today. Only reached 8500 RPMs. Grenaded belt doing 60 down the trail at the end of the day.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
Is anyone getting Yamaha to replace the belts?
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Lol ! They are not gonna replace belts, they won't replace secondary or primary springs which are causing the clutch/binding which takes tole in belts!. Complete BS imoIs anyone getting Yamaha to replace the belts?
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Should have just bought a cat with team clutches they don't have any issuesLol ! They are not gonna replace belts, they won't replace secondary or primary springs which are causing the clutch/binding which takes tole in belts!. Complete BS imo
race24x
- Dec 29, 2003
- Belgrade, Maine
Nice I bought another Yamaha because they had less issues than most. Now I have a Arctic Cat chassis with a Yamaha engine that blows belts like a Skidoo WTF
Triple tamer
- Feb 26, 2017
- St Clair, Mi.
- 2015 Ski-doo
Just when I thought I understood clutching with my 2012 f-1100 turbo, now all this reverse helix angle stuff is confusing the crap out of me. Cam someone please help me understand ? You have a starting angle and a finish angle or just straight. The 1100 loved to be loaded with aggressive weights and aggressive helix. So this new triple clutching seems a little different unless it's a cat clutching thing.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Reverse angle helix is when the start angle is lower (smaller number) than the finish angle (larger number) in degrees. Traditionally the starting angle is larger, but with turbos the lower starting angle helps to spool a large turbo. Not really needed on the sidewinder.
I'm not sure I agree with folks who say the helix angle is too shallow. the new roller secondary has a lot larger diameter than the old yami helixes, and it's a roller which means helix angles needs to be reduced to get the same performance as a button clutch.
I don't have a Sidewinder for testing so it's hard to say what's going on.
JestersYamacat
- Feb 20, 2013
- 2017 Sidewinder LTS-SE Black/ Orange, 2012 xf1100lxr Green
- Kanata, Ontario
I would agree for the majority of the time but the idea of the lower angle was to get it to rev quicker and clean up the soft low end and make it snappier in the corners. It is not bad and the mid range is fantastic. but getting there at times could be better. RockerDan also talked about this a bit in his earlier posts and after getting my new sled I agree. My old turbo was sluggish until I clutched it and after it was great. Like was said earlier about higher angles and weights was true for it.
Jester
race24x
- Dec 29, 2003
- Belgrade, Maine
I am just a little disappointed that Yamaha on sleds with only 500 miles doesnt think a blown belt or a bad spring shouldnt be covered by warranty. My sled is stock I ride on groomed trails, I am not out on a frozen lake. It was basically perfect snowmobile conditions with some loose snow on the trail for lube for the slides. Yet it still blows a belt WTF. I will be replacing the clutching with a kit as soon as I hear about one that has been tested and is bullet proof. New springs helix whatever. I dont think it needs the performance I just want the damn thing to be reliable.
Triple tamer
- Feb 26, 2017
- St Clair, Mi.
- 2015 Ski-doo
Well I pick my new winder up tomorrow they got hammered with snow in northern Michigan. Riding it stock obviously but I will be looking for clutching Parts's.I would agree for the majority of the time but the idea of the lower angle was to get it to rev quicker and clean up the soft low end and make it snappier in the corners. It is not bad and the mid range is fantastic. but getting there at times could be better. RockerDan also talked about this a bit in his earlier posts and after getting my new sled I agree. My old turbo was sluggish until I clutched it and after it was great. Like was said earlier about higher angles and weights was true for it.
Jester
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Agree Bud.....I would agree for the majority of the time but the idea of the lower angle was to get it to rev quicker and clean up the soft low end and make it snappier in the corners. It is not bad and the mid range is fantastic. but getting there at times could be better. RockerDan also talked about this a bit in his earlier posts and after getting my new sled I agree. My old turbo was sluggish until I clutched it and after it was great. Like was said earlier about higher angles and weights was true for it.
Jester
When talking helix angles, I like to refer to the angles as "steeper" and "shallower".....Rather then higher/lower angles, or More or less angles. IMO these terms dont register as well in someone's brain. Using steeper and shallower(or flatter) makes one picture that image in their mind, like a steep mountain road.
Typical Helix angles starting steeper, and ending shallower are much more the "norm". Using torque in the bottom and middle(steeper) then finishing shallower/flatter on top end to climb and hold up rpms on long lakes ect...
A reverse angle would start shallower/flatter, then go to the steeper angle on top end. So now the shallow/flatter angle down low speed wont upshift as fast, holding rpms UP/Higher on trail speeds, corner to corner you will be revving more and so now you are pushing more PSI boost corner to corner in the 5000-7000rpm range. Similar to the high start rate compression springs we install in the DOOs to make them rev down low, and pop skis at will with instant snap of flipper.
Using a 33/35 reverse helix will hold rpms bottom/mid (33 initial angle) up more then stock 35 straight, and then get onto the 35 angle for top speed which should get the upper rpms close to stock 35 straight.
A stronger side force torsion spring can have a similar effect, and Dale is working on one as Im sure others are for next season. We should see alot more tuning tools in clutching next season for the SW along with tunes that will bring on boost lower. I know my cat when tuned/clutched would hit super hard down low, and snap skis off the snow quickly....SW will be total package when we get them strong on bottom too.
Dan
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
just did 127 speedo with steeper helix. Then stock. No doubt in my mind steeper is better. Stock gears. TD ECO TRAIL. TDturbo force muffler. Snapped skis off @75 mph on hard packed road. 137 coupled skid. 192 nails.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
38 straight?just did 127 speedo with steeper helix. Then stock. No doubt in my mind steeper is better. Stock gears. TD ECO TRAIL. TDturbo force muffler. Snapped skis off @75 mph on hard packed road. 137 coupled skid. 192 nails.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes sir , ,straight 38. Straight 37 would be very good also imo. 200o miles on with set up. NO BLOWN BELTS.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I have tried to break the 8dn. No luck. Not holding for 5 minutes or anything like that. But just hammering it at every speed imaginable.
