ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yes sir , ,straight 38. Straight 37 would be very good also imo. 200o miles on with set up. NO BLOWN BELTS.
what did you do up in primary to keep rpms up? Any slippage on primary?
I have tried to break the 8dn. No luck. Not holding for 5 minutes or anything like that. But just hammering it at every speed imaginable.
I agree here, the 8dn with its length, I set deflection up similar to a DOO belt, to get it perfect(remove one shim) and have not hurt it. Still went 125.2 on stalker gun, so assuming +3mph with 8jp as others have said they are worth 3mph with shorter belt.
Id like to test a shallower start to hold RPMS up on trail, for more bottom/corner to corner snap.
Dan
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Dan did you want this 35/37?
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
35/37 would give you best of both worlds right? Is it machined for the springs better and so the OD works?
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Yes and also machined a bit for OD.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Had NOS machine primary for a smidge overdrive. Also my secondary pocket. AND machined for 8dn belt. I have ZERO slippage up top it holds and even gains just 100 rpm. BOTH clutch sheaves clean as a whistle. 2400 miles and it's a beast. 850 is not even remotely close out of the hole or rolling. The biggest thing that I like and feel is the pull when whacking it at 60-70. I also took 2mm off the top of my helix hub
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Guys Jon has a very good running setup. I had something very similar and we shared some stuff. Thanks and cheers.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
What secondary spring did you use with that helix? thx
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Helix is brand new. As in never been in a sled.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You get yours dialed? Mine scared me a bit today on a plowed road. I raced a guy and pulled the skis at like 75mph. Got squirrel like on me. 0-100 it's just amazing. 330 miles yesterday and today. CHEERSGuys Jon has a very good running setup. I had something very similar and we shared some stuff. Thanks and cheers.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Hate to say it but I sold mine. Got more than what I paid for it minus some goodies. I like that murdered tcat for next year. You know the sled that has inferior clutching? Lol. Already have the gears for it and the belt I will be using.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
What are you running in the primary? What wrap on the secondary?just did 127 speedo with steeper helix. Then stock. No doubt in my mind steeper is better. Stock gears. TD ECO TRAIL. TDturbo force muffler. Snapped skis off @75 mph on hard packed road. 137 coupled skid. 192 nails.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Go back a few pages on this post. I have it all posted otherwise pm and I will help as much as I can. Might be few days as I am up at cabin riding. Last ride for the yearWhat are you running in the primary? What wrap on the secondary?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Stock secondary spring with straight 38 helix?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes wrapped 3/3. Had it wrapped at 6/1. To much back shift at 6/1 for me.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Well the 18 t cat looks tight. Keep in touch if possible. Good chatting with youHate to say it but I sold mine. Got more than what I paid for it minus some goodies. I like that murdered tcat for next year. You know the sled that has inferior clutching? Lol. Already have the gears for it and the belt I will be using.
