yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
alright thanks guys i got it figured out
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Essarex said:if the main bolts are free to rotate in the bulkhead, they will blow away the thin stock bushings and egg shape the bulkhead holes. the oillite replacement bushings help because they last longer, but this is no way to correct a design flaw. the a-arms have plenty of freedom to rotate without needing the main bolts to turn.
Our bulkhead kits eliminate bolt rotation in the bulkhead bushings.
kidastra
Thanks for a great write up. In the process of doing mine today
I bought my kit from the local classified and it came with a bunch of bushings. Any idea what the 2 bigger sizes are for?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
There is one on the bottom of the spindle
APEX 06
- Apr 30, 2009
- Sheboygan, WI
kidastra
Number 17? I guess that's the largest one, know what the other is?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
That should be #57,19 the lower hole on the spindle for the lower arm.
kidastra
I'll double check tomorrow but they looked way to big
mr. shide
nice write up, looks like nearly the same procedure as accessing the oil filter
APEX 06
- Apr 30, 2009
- Sheboygan, WI
mr. shide said:nice write up, looks like nearly the same procedure as accessing the oil filter
For the most part the same thing.
kered
- Mar 22, 2014
- Newmarket, Ontario
- 09 Apex GT
Do the collars need grease when doing the a arm bushings?
Pärra Olsson
- Oct 17, 2014
- Sweden
- Sweden
- APEX XTX -12
If you look at the instructions, you can put those one's in from the front. I also used cleaned engine oil when installing mine, mad it a tad easier to get them in.
I have bought Yamaha oem Oilite bushings SMA-8FTFR-KT for my Apex. Is this kit the same as Ulmer Racing sells? In Ulmers instructions you can put in the bushings from the front. Can anyone confirmed that even is so with the "yamaha olite kit"? I think it`s the same, made in United States! I think Oilite is a fabric or a brand.
Greetings from Sweden!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Same thing
spr5088
- Jan 9, 2014
- Poughkeepsie NY
- 03 rx1
Are the caps pictured in photo 30 necessary? Changed my bushings and a couple of them were cracked. I cannot find a part #on the diagram or a number on how many there should be.nthe machine is a 2003 rx1
youngdman
- Jul 19, 2012
- South Portland, Maine
- 2006 Yamaha Apex
I had a few caps destroyed so I used a washer to take up the space to keep everything tight. Have ridden it 250 miles since and everything is still tight. Now that I have done this once if I had to do it again I'm sure it would go much quicker and easier.
- 28K
- 161K
