APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
How to for replacing a-arm bushing.
From bottom to the top
Step#
1 remove the nose panel
2 headlight bolts
3 remove headlight bolts
4 removing hex head bolts
5 remove it
6 removing headlight pod
7 remove headlight pod from sled
8 remove 4 hex head bolts from intake boots
9 remove sensor
10 remove hose
11 remove hose from under air box
12 remove air box from intakes slowly
13 remove oil line
14 how it should look with out air box and headlight pod
15 remove strap from battery box
Step#
2 headlight bolts
5 remove it
9 remove sensor
10 remove hose
13 remove oil line
8remove%204%20hex%20head%20bolts%20from%20intake%20boots.jpg304.9 KB · Views: 2,027
14how%20it%20should%20look%20with%20out%20air%20box.jpg553.7 KB · Views: 2,318
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 16-34 starting from the bottom up.
16 battery cap
17 remove battery cap
18 remove both top bolts for the battery holder
19 remove both bolts
20 remove the two lower bolts for the holder
21/22 remove fuses
23 nut on bolts for a-arm inside the engine bay.
24 top bolts for a-arms, same for both sides
25 lower bolts for a-arms same on both sides
26 cover the intakes with tape
27 remove bolts for a-arms
28 remove bolts for shocks
30 cap on a-arms
31 remove cap to see bushings
32 bushingd in a-arms need to be pop out
33/34 remove bushings from bulk head front and back
16 battery cap
21/22 remove fuses
30 cap on a-arms
18remove%20both%20bolt%20on%20the%20left%20and%20right%20side.jpg415.2 KB · Views: 1,946
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Put in new bushings and put back. Takes me about 2 hours to do this job.
Super Sled
- Feb 25, 2009
- Summit X
Great DIY thread!!!!!!!!!!!!!!!!
Great pics and really nice job. Posts like these are really helpful to people.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Nick1945
Thanks for the info and the pics, which is one of the great things about this site, people always helping others out.
Super Sled
- Feb 25, 2009
- Summit X
This should be a "sticky" for sure, or be included in the "Apex FAQ's" sticky.
IMHO one of the best DIY threads out there!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Thanks for the great writeup, definitely saving this to my favorites
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Added to the Apex FAQ and both RX and RS forums
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Crewchief47 said:Added to the Apex FAQ and both RX and RS forums
Thanks Crewchief
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Irv said:Crewchief47 said:Added to the Apex FAQ and both RX and RS forums
Thanks Crewchief![]()
X2
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
awesome diy, been looking for this for when i change mine..
sticky indeed
subaru2006
sticky indeed
subaru2006
shawnj
When do these bushings tend to need be replaced? My wife drives an 08 Apex with approx 4000kms, is this something I need to be looking into, or how can I tell if they need them replaced??? On my2010 apex, are they any different than the 08? Thanks.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
shawnj said:When do these bushings tend to need be replaced? My wife drives an 08 Apex with approx 4000kms, is this something I need to be looking into, or how can I tell if they need them replaced??? On my2010 apex, are they any different than the 08? Thanks.
From the reading I have done, it seems there is no real set of milage when they can go, meaning some gets lots of miles out of the factory ones and some hardly any.
I read once where spraying a lube all around the bushings so it creeps into them can help so if you have no plans to replce them this year then this is a good mtce tip.
Aren't the 10's greaseable? I thought they came from the factory with grease nipples already installed? (maybe it's the 11's?)
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Pick up the front end and see if you have movement in the A-Arms.
- 27K
- 155K
