Technical Bulletin S2014-001. Reverse Update
Fyi, you do not need to remove the actuator to see if this upgrade had been performed. Look below the actuator and you can see if the spring is present. About a 1/4" of the spring should be exposed.
I am lost I put this back in after changing my gears on sidewinder and it seems like once I put plug in with gears pushed in I go to put actuator on and it's just a bit off and if I tourqe it to line bolt holes up the plug moves out of the grove?! Can someone help? :o|
You are allowed to torque it that little bit. Most important final step is to start sled and go in and out of reverse 3 times before moving it. This sets home on the mechanism. Relax you are almost done buddy!
