Winderman69
- Dec 31, 2016
- New york
- 18' sidewinder RTX 50th anniversary
Coming across a field not very fast and all of a sudden a weird noise... Thought it was a belt blowing but never quite heard it like this before, pull cover belt is fine, start back up and try to move but all I hear is grinding. Try reverse and it moves fine, try forward again and nothing but grinding, dealer says probably a bad top gear but of course he can't have it fixed till maybe Saturday ( I took today and tomorrow off to ride cause rain and high Fortys on the way). So I hitch hike back to my truck and trailer go pick sled up off the trail and drop it to him. Couple this with a top speed of 104 mph any him pissing me off its off to the doo dealer as soon as I post this.
Teamsynergy
- Feb 14, 2016
- Indiana
- 13' Ski-Doo 1200 Gade
18' Yamaha Sidewinder LTX-SE 137"
Its a first year sled... there will be bugs for sure... look what the procross went through! I hope that these don't experience the same fate however, knowing how Yami builds their stuff, it will be resolved sooner vs. later and not with bandaids. Stick around and enjoy the coolaid... #*$&@ happens
Jasonk
2nd year of the sidewinder
Teamsynergy
- Feb 14, 2016
- Indiana
OP has a 2017.... FIRST year for the SW.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
5th year for the BS chaincase, I have the same chaincase on my viper and it’s junk. All my older yamaha sleds combined didn’t have as many issues as this viper. I’m putting up with it 4 now.
Teamsynergy
- Feb 14, 2016
- Indiana
Yes, there are a few carry over items from other sleds however, there are a lot of additional variables added in with the sidewinder IE HP vs the viper in stock form.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
https://ty4stroke.com/threads/sidewinder-upper-gear-with-oiling-hole.150428/page-7#post-1405562
Here is the fix for top gear they have known about for years. Haha then they forget to finish drill the lousy oil hole through the bushing! And yes all the bearings on this sled are Chinese garbage, but all sleds are going that way so it doesn’t matter what you buy anymore they are all made to fail sooner than later.
Winderman69
- Dec 31, 2016
- New york
Very frustrating worst part is I have nothing to trade in on something new right now because it's getting fixed... it's a fun sled but this one doesn't perform like all the ones people post about on here, and now with this problem after 1450 miles it's gonna be hard not to jump ship..??
Grimm
Unfortunately, a few days in the shop is an eternity to a sledder, especially when you get time off work.
I feel for ya.
I feel for ya.
Teamsynergy
- Feb 14, 2016
- Indiana
I feel for ya.
Agree 100% as our riding days seem to be short every year!
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
I don't love the design at all....BUT I have now owned 4 of these sleds with that crappy chaincase, and NOT once did I ever have failure.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well if you get a new sled every year you Probably wouldn’t see it. Guys are replacing the upper gears every year so they don’t have a problem, your just replacing the whole sled. LolI don't love the design at all....BUT I have now owned 4 of these sleds with that crappy chaincase, and NOT once did I ever have failure.
Drive shaft bearing and jackshaft bearing on the clutch side are both garbage. Tolerance is so loose many are spinning on the shaft. I pulled the seals out of both to repack with grease and found them bone dry at 2000 miles, seals are junk they practically fall out. I never even touched a bearing on my old viper until 6000 miles and they still had grease in them. Tri Hub failed at 1200 miles, starter failed at 700 miles, several issues with relays causing sled to shut down. There’s wires rubbing everywhere on this chassis, I have fixed what I found so far. I have skid rails that have oblong holes from loose bolts. There’s more I just can’t remember it all.
WinterWolf
- Mar 25, 2017
- Connecticut
Mine is a new 18 (417 miles on it), but for next year, what aftermarket bearings do you suggest for the Drive and Jack shaft bearings on the clutch side? Or just replace those bearings every year when doing preseason maintenance??
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Some guys are upgrading to new brand name bearings. I personally have been pulling apart and repacking with fresh grease yearly. Maybe next year I’ll replace them with SKF brand. The upper jackshaft bearing in your chaincase has already been changed to a new design.
- Status
- 7K
