Chris600
You have PM Upbushman, I want to buy both your kits
UP bushman
Update on the product at beginning of thread.
Ruckus
Great work man. I had a TON of slop in that area.
multip
- Oct 30, 2007
Hi UP bushman you have PM, interested of Steering Pivot Arm Bushing Kit
Muffin
- Oct 5, 2006
- Marathon, WI
- 2014 SR Viper RTX SE
Send me a kit.
PM sent
Thanks!
PM sent
Thanks!
franklin
got kit installed and all is tight Thank You very much
UP bushman
Thanks all you TY folks for the great comments on the product . This site has been a wealth of info for all of us and it's nice to be able to contribute a product reasonable priced to fix a major issue thanks again Rob.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Send me a set.
PM sent!
PM sent!
Stonetire
Hi UP Bushman!
And you have another customer for the steering bushing kits. Please see my PM.
rans9titan
- Oct 24, 2011
up kit
I recently purchased a 2007 phazer with 4500 miles on it. Well it had just over 3/4 of a inch of slop at the bars. I got his bushing kit and installed it tonight. I got it back togather and now down to 3/8 to 5/16 of a inch. I dont have any slop where I put the kit in worked great. Kinda tight but figure it will wear in pretty fast. I kept taking things apart to find the rest. Most of it is the small link right at bottom of the bars. The rod ends have almost a 1/4 inch of slop in them so will have to get a new one since they are molded right into the link. I also had alot of play in the upper plastic handle bar holder. I see oft says they are out of stock so came up with my own fix. Took the holder off the sled. I took out the steel bushings that are around the bolts and cut off about 1/8 of a inch. Then I took one of the bushings and cut it down about the same amount. I put it back togather with nylock nuts and tightened it just enough to take all the slop out. I have a small gap between the plastic pieces of a little more of a 1/16. I can now tighten it down some more when it gets wore out. Cheap fix that should last a few seasons I should think.
canoehead
- Jan 14, 2011
- NE, Alberta
Re: up kit
Got Pics?rans9titan said:I recently purchased a 2007 phazer with 4500 miles on it. Well it had just over 3/4 of a inch of slop at the bars. I got his bushing kit and installed it tonight. I got it back togather and now down to 3/8 to 5/16 of a inch. I dont have any slop where I put the kit in worked great. Kinda tight but figure it will wear in pretty fast. I kept taking things apart to find the rest. Most of it is the small link right at bottom of the bars. The rod ends have almost a 1/4 inch of slop in them so will have to get a new one since they are molded right into the link. I also had alot of play in the upper plastic handle bar holder. I see oft says they are out of stock so came up with my own fix. Took the holder off the sled. I took out the steel bushings that are around the bolts and cut off about 1/8 of a inch. Then I took one of the bushings and cut it down about the same amount. I put it back togather with nylock nuts and tightened it just enough to take all the slop out. I have a small gap between the plastic pieces of a little more of a 1/16. I can now tighten it down some more when it gets wore out. Cheap fix that should last a few seasons I should think.
Hey could anyone help me, got some problems installing a new steering bushing(name?) the thing that goes around .... well its just that im not able to get the thing out becouse it´s a metal frame around it and not alot of room(dont want to drop everything in to the engine....) can take a picture later if u dont understand.
And the only way do get the "frame" away seems to bee, unscrewing the inter chassie
The sled is a phazer mtx 2011...
MotoPsycho
Emme.g.h. said:Hey could anyone help me, got some problems installing a new steering bushing(name?) the thing that goes around .... well its just that im not able to get the thing out becouse it´s a metal frame around it and not alot of room(dont want to drop everything in to the engine....) can take a picture later if u dont understand.
Your question was answered in the other thread; correct?
rans9titan
- Oct 24, 2011
Sorry I didnt take any pictures. The only problem I see with the steering head fix is that the metal piece in the back that has the bolts welded in shows a slight bow when you tighten it down. The front piece may also be bowed a little. If I had it apart again I would put a brace on both of them to make them a little stronger. Will see how it holds up.
- 48K
- 149K
