yamahas said:I can't open the diagrams right now but I think the hose you are talking about are air pressure hoses. They are attached to something else at the other end.
Diagrams are on page 6 in this thred.. This hose is at the very bottom of the air box and on the unfiltered side... The other end doesn't look like it has been attached to anything but I could be wrong.. I'm guessing water drain hose.. Oil breather and three vacuum lines on the upper part of air box are all good..
I believe you are right.Drain Hose.
yamahas said:Bomba, I was also only able to get one under there or the allen screw would not fit in it's slot. They where also very tight on the shaft.
For the steering shims I got two underneath and no room for the upper shim.. I might try to grind it down but I think it will do as is?
irish_redneck
Couldn't get the upper shim to go in and still have ability to re-install clip....
Incredibly tight even without it in though.
UP bushman
irish_redneck said:Couldn't get the upper shim to go in and still have ability to re-install clip....
Some times the top one does not fit and is just to finish off detail. I found leaving the steering arm bolt loose and pulling up on shaft while pushing down steering arm. Then try to put top washer on then clip and tighten steering arm bolt last. It's surely night and day when kit is installed thanks for the comments folks.
Weapon X
UP this is a real nice kit! I would have to say that over 80 % of my steering slop is gone, I'm sure the rest is in that steering post from looking closely at things, Thanks bud!
chad450r
Happy Customer
Thanks Rob, worked like a charm, other than opening the box in my truck and one pesky washer fell down under the seat. lol Thanks again nice product.
Thanks Rob, worked like a charm, other than opening the box in my truck and one pesky washer fell down under the seat. lol Thanks again nice product.AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
I need to buy one of these kits !!!! where ?
Just PM UP Bushman. He does wonderful work.
AIRWOLF
Guest
- Oct 1, 2004
- New York
cannondale27 said:Just PM UP Bushman. He does wonderful work.
sent a PM 3 days ago , waiting for a response
thank you
He might be on vacation. Dont worry he will take good care of you.
AIRWOLF
Guest
- Oct 1, 2004
- New York
cannondale27 said:He might be on vacation. Dont worry he will take good care of you.
thats what I was thinking,
Phazer Lady
My husband is an average mechanic. He works on our bikes all the time. We bought this steering kit but I am wondering if we need to send it out to a shop? I asked him if he thought it was going to be easy and he just said "I'll figure it out".
If he does it wrong will my steering be all wrong?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
No need to send it out to a shop. The instructions that come with the kit are very good.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
yamahas said:No need to send it out to a shop. The instructions that come with the kit are very good.
Yep, my neighbor did Irish Redneck's last season- some things to take off & dig into but ya' learn what's involved with the sled...
Doing mine in couple weeks when the $$ tree drops more leaves
** UP, sent you a PM
