Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Terrible thing to only have 270hp.So for 91octane users we are still limited to 270hp even with header and pm tunes.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I got a good chunkle out of that one! ^^^
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
I ran 3r pefi for 3000 miles and no issues without header. Safe is as safe as the operator.
The header is lower boost(2 psi) same hp
Flex I would assume is better.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Ill take me 500 Hp and lower IAT's . LOLThe big intercooler will permit you to run the SAME horsepower longer as it keeps iats in check. IMO the big intercooler hanging off the front says, "Hey look at me, I have a big turbo with 500hp." Then you get smoked by a sled running Powertrail and everyone laughs at you.
A header allows more power with less boost on lower octane, which are the advantages. All things being equal, a sled with a header will outrun a sled without it. The disadvantages are as you state; They are pricy and there is a risk of burnt bellow, possibly sled burning down etc.
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
Are they proven to work?
I have one and I drilled the plate out behind the intercooler which you can see on Tommcat website. I don’t see a big difference but idk. The problem is the damn intercooler is always covered with snow/ice. I’ve never used hurricane under hood which I assume is better?
Short distance performance it doesn’t matter unless you run back to back to back.
SledFreak
- Feb 7, 2005
- Ontario. Canada
I wouldn’t think the risk of running a header is any more risk then changing from the stock tune to a aftermarket tune! Besides the cracking where is the risk? Or is it because of the cracking!The big intercooler will permit you to run the SAME horsepower longer as it keeps iats in check. IMO the big intercooler hanging off the front says, "Hey look at me, I have a big turbo with 500hp." Then you get smoked by a sled running Powertrail and everyone laughs at you.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The stock manifold has more airflow between it and the fuel tank, that is what I gather from the comments.
Cracking (and ruining a trip) are certainly one of the bigger considerations as well.
stgdz
- Mar 27, 2021
- Buffalo MN
Not really my point, but I have seenTerrible thing to only have 270hp.
-cai intake adds 5hp
-pm adds 10-25 depending on flow
-header adds 10hp
So some may think adding 1 and 2 gives about 15 more hp.
Dave lists 270 as the limit for 91 and pretty much anything higher than that requires 93. He does have header specific tunes and I'm curious as to what changes with the header tunes. The engine can breathe easier so my guess is boost and timing may be pulled (not a bad thing!).
stgdz
- Mar 27, 2021
- Buffalo MN
Makes me wonder when we are going to see flex fuel e85 tunes.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
As mentioned in another post, the advantage to the header is increased response and the same power level at a lower total boost psi. hurricane 270 runs 15 or so psi on header tune vs 17-17.5psi on stock manifold.Not really my point, but I have seen
-header adds 10hp
SledFreak
- Feb 7, 2005
- Ontario. Canada
What does Hurricane do to the stock manifold that makes it worth 1200.00 upgrade? Thats more then his header? What is the difference in Power compared to his header?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
That must be header plus appropriate muffler? The implication is that the stock manifold is a LOT more restrictive.
Turboflash
- Mar 18, 2019
- Southern MN
Is it REALLY 91? Who knows these days (especially here in MN). A little Boostane goes a long way.
Turboflash
- Mar 18, 2019
- Southern MN
IDK for sure but from what someone posted here in TY, they cut it apart, port/reconfigure it, weld it back together.What does Hurricane do to the stock manifold that makes it worth 1200.00 upgrade? Thats more then his header? What is the difference in Power compared to his header?
justinator
- Mar 25, 2007
- Maine
Sidewinder Stock Manifold
Time for port matching, it probably won’t gain much but it gives me something to do .. lol The Yamaha exhaust gasket is matched almost perfect to the head outlet openings, makes you think Arctic cat made the exhaust manifold.. lol
- 16K
- 12K
- 8K
