Compared to stock muffler?3 inch is 10-15 hp on larger tunes
It’s significant
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
Compared to 2.5. I quit running them after seeing this on multiple sleds
Wow, that's a great gain over the 2.5Compared to 2.5. I quit running them after seeing this on multiple sleds
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
I guess? Maybe dynos lie?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Is this a estimate or are you comparing dynosheets?Compared to 2.5. I quit running them after seeing this on multiple sleds
I haven't seen any dyno sheets comparing mufflers yet, but would definitely like to view them!
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Following!Is this a estimate or are you comparing dynosheets?
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
TD claims 7hp extra going to 3" over 2.5", of course this will vary depending how crappy your 2.5" muffler is and how good your 3" is. In the case of TD he was referring to the 2.5 vs 3" superquiet which both use a magnaflow straigh through muffler. If you have a straight though 2.5" muffler with no chambers your gains will be minimal going to a 3". If your current 2.5" is chambered the gain to a 3" straight through will be more pronounced. In my case of 2.5" sq to 3" viney fab which are both straight through magnaflows I saw about a 75-100rpm change on 17.5-18psi tune.
SideHogger
- Apr 16, 2016
- upstate ny
Any idea how the new TD Super Mod Stock muffler compares?
justinator
- Mar 25, 2007
- Maine
Have no experience with that muffler but people seem to be happy with the noise/power balance. If I was a betting man I would say it comes in less powerful than the 2.5" superquiet but at a reduced noise level since it isnt straight through which is what alot of people are after.Any idea how the new TD Super Mod Stock muffler compares?
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
So, I currently have the Hurricane SM270 tune. Does the PM270 make the same power but at lower boost pressure?
justinator
- Mar 25, 2007
- Maine
No, boost pressures should be very close. Power will likely come on sooner and harder and if your trying to attain bigger speeds of 125+ i think the pm will help there. The header tune will make same power at lower boost pressure. I believe 270 header pm tune runs around 15psi vs the 17-17.5 of stock manifold.So, I currently have the Hurricane SM270 tune. Does the PM270 make the same power but at lower boost pressure?
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
The hurricane SM270 turns into the PM300 with a separate tune for PM. The SM Multi-map is 225-240-270. The PM Multi-map is 240-270-300.So, I currently have the Hurricane SM270 tune. Does the PM270 make the same power but at lower boost pressure?
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Ok interesting. So can you just bolt on a PM or is the tune different between a 270sm and 270pm? Maybe different timing curves?No, boost pressures should be very close. Power will likely come on sooner and harder and if your trying to attain bigger speeds of 125+ i think the pm will help there. The header tune will make same power at lower boost pressure. I believe 270 header pm tune runs around 15psi vs the 17-17.5 of stock manifold.
justinator
- Mar 25, 2007
- Maine
That tune is different, different fueling requirements for sure and possibly some other tweaks that only the tuner would know.Ok interesting. So can you just bolt on a PM or is the tune different between a 270sm and 270pm? Maybe different timing curves?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I posted this in another thread, but here are the claims by muffler for TD:
- 17K
- 12K
- 8K
