stingray719
I did the fan reverse just as you described above this evening. Started it up and let the fan cut in man there is a lot of hot air coming out of there.
You should see all the heat comes out from under a turbo hood with fan reverse!
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
One Question when you did this did you tape it of just plug it in? (as the clip don't work when turned)You should see all the heat comes out from under a turbo hood with fan reverse!
Its a Weatherpack Connector just go to any auto store and they have the tool to remove wires from plug without harming them. Just reverse them. Another option is to buy a harness from Barn Of Parts.One Question when you did this did you tape it of just plug it in? (as the clip don't work when turned)
stingray719
Turned it around and used a plastic wire tie. Probably better the way Canondale did his though.
jsslye
- Nov 20, 2015
- Marilla, NY
- 2016 Yamaha SR Viper LTX-LE
Gone but not forgotten:
2009 Nytro RTX-SE
1999 Vmax 600 SX Triple
Did Yamaha reverse this for 2016? I was doing the pre-break in warm ups and the fan kicked on - felt like the hot air was being blown out the sides and front of the hood, not up through gauge cluster area.
stingray719
Well, I did forward this mod to Yamaha so I will be interested in seeing if it is reversed now.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I have a 2016 and mine was pulling air in threw the rad. Then I switch the wires and now in blows out.
jsslye
- Nov 20, 2015
- Marilla, NY
2009 Nytro RTX-SE
I'll double check it. If it is reversed, there is also the possibility that my dealer switched the wires right out of the crate.
Zrxpilot
Ok. Im sold. Dumb question. So.. step 1. Find the fan. Step 2.Find the nearest plug to the fan. Step 3. Assuming there is only two wires running the fan and lets say the colors are blue and red...simply swap the blue for red. Seriously, its that easy?
pjabas
- Feb 11, 2013
- Montgomery ,MN
- 14 sr viper xtx se. 153" track turbo
Yes it's that ez, the connector was close to the fuse box on mine
stingray719
Yep, easier yet with Barn Of Parts adapter.
Jim R
- Aug 30, 2015
- Rockford MI
- SR Viper / Procross
Its that easy. Zero cost if you rotate the existing plug. Apply a small amount of pressure and it will mark where you need to slot the opposite terminal. razor knife a similar notch and zip tie once together. If you ever want to go back remove zip tie and rotate back to stock.
- 46K
- 10K
