monsterattak
a silly question maybe but... has anyone looked into aftermarket bars or hot grips to determine if they would swap in for the 06' bars and be wired the same and therefore producve heat. I have the 06' bars and used the harness and so i have heat now but i wouldn't mind a wider bar.
maybe this could be the answer for guys that can't get or don't want the 06' bars? I have no clue how the aftermarket stuff is wired...
Metallicat
I was wondering if just the 2006 Yamaha grips could be ordered and installed / wired on the 2007+ bars, or were the 2006 bars much different from the later ones?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Somewhere back in this topic somebody already looked into this. I seem to recall that the bar diameter is different?
Metallicat
Blue Dave said:Somewhere back in this topic somebody already looked into this. I seem to recall that the bar diameter is different?
Thanks Blue, I figured the answer was probably buried somewhere in the 40 pages of this topic!
wigyami
hot hands
While I fired up the wife's sled today new 08 vec gt with o miles with the 06 bars I install this summer- hot,hot on 2 bars, thanks for the fix. It was luke warm on high with the 08 bars in 60 degree weather like today when I bought it home, and real toasty on 2 bars with the 06 bars today.
Pureadrenaline
Has anyone figured out if the fix will get too hot and cause damage?
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
There"s quite a few people that have been running Dan's fix for a season or so now, and as far as I've read, there havent been any damages. I have the '07 parts to do my sled, and will be running it this season.
Pureadrenaline
Sounds like I need to get the 07 wiring harness then. Should people still foam their handlebars?
Thanks,
-pure-
Thanks,
-pure-
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
From what I have heard, the '06 bars in an '07 circuit will get hotter than you would ever need. Therefore foaming the bars should not be necessary.
nate007
- Dec 25, 2006
- Iowa City, Iowa
I haven't followed this trilogy as much as some, but from what I remember, most have said that foaming the bars is only a marginal effort. But - it's a cheap fix, so no harm either way. I haven't done anything to mine, and probably won't. (foam)
Pureadrenaline
ok im probably going toget the 07 harness, anyone remember how much it is?
thanks,
-pure-
thanks,
-pure-
SLEDSTART
Does anyone here know what the difference between the 06 and 07 bars are? I don't mean the warmers...but in shape or diameter?
Will I be losing out on anything putting the 06 bars on my 07?
SharkAttak
the 06' bars are thicker with removalable hook's the 07' are skinner and are one piece and are worthless, with the 06' bars and the new harness you won't be putting your warmers past 3 bars or you'll cook your hands
SLEDSTART
Thanks shark. So the overall shape is the same and I won't really be losing anything and I'll have harm hands to boot! Still debating on hand gaurds and what ones work if any!
I can't belive this thread is 40 pages long!
06apexrtx
well i just got my new updated bars from a dealer and except for the hooks they look pretty close. i cant beleave this 5" wire narness is the fix.
- 147K
